Originally Posted by Phase700B
It's kind of a *wild card* with GS calibrations. It depends on the skill and experience (and interest) of the GS tech you happen to get. Every now and then here on AVS, we will read that a new TV owner is happy with what GS has done for their TV calibration. More often. . . . not so much.
But on this TV. . about the only critical settings are the RGB white balance. Plus. . if you do not like the results you can always reset the TV to default and start over on your own from scratch.
So, Phase700B (and possibly others) - do you think getting a pro calibration is overkill for this TV given the limited range of settings? I've asked this question before and also asked it of the calibrator (Gregg Loewen) I'm using but I've never heard anyone say it was not worth the money. Setting the RGB whites, gamma, etc. and even the backlight level correctly for a given room require having the right equipment and software + the knowledge, skill and patience to use them correctly. Numerous people on this thread and others have stated that these settings are NOT the kind of thing you can simply eyeball. I decided - rather than invest the time and money in acquiring the right tools and skills, etc. - to just pay someone who will do it right the first time and will also spend the time to educate me as he does so. I do feel like it'll be worth it knowing I'll be getting the TV's full potential.
I went through AVS HD709 a few times and feel like my basics (black, white, color, tint) are sound. That's the stuff any owner of this type of TV oughta be able to do with a free disc and a cheap set of blue filter glasses from THX (no blue mode on my model). It's the other stuff you mentioned that I'd really rather not just "fiddle" with and that I think will make a difference in the overall viewing experience. I've experimented with the AMP settings, color modes, etc. but not the RGB whites because from what I understand, those should be set with the assistance of a colorimeter (and its software).
