Originally Posted by
chughes737
Just got this TV from best buy after my 2 year old (WTF????) Samsung 55" UN55B6000 died
Anyways, this took a little longer than that TV to set up but now I am extremely happy with it
First off my settings:
Using HDMI1 for DTV and HDMI 2 via AV Receiver for PS3 and Xbox 360
Mode: Standard
Game Mode: On for HDMI 2 input (consoles)
Backlight: 18-20 (I prefer 20 since I turn down the brightness)
Contrast: 100
Brightness: 37
Sharpness: 23
Color: 37 (gaming 45)
Tint: G50/R50
Color Space: Native
White Balance: Default
Gamma: 0
Dynamic Contrast: Off (Initially gives a pop but crushes blacks and blows out the whites - better to tweak with off)
Black Tone: Dark (nice little darkening without crushing any blacks in the spectrum)
Flesh Tone: 0
Motion Lighting: Off
Color Tone: Standard
Digital Noise Filter: Off
HDMI Black Level: Normal (gaming with Full Color PS3 and Expanded on Xbox 360)
Film Mode: Off
Auto Motion: Clear / Gaming Off w/ Game mode on
LED Motion: Off
Before I get into the pro's and con's first a point about the Sharpness vs Digital Noise Filter settings. I went back and forth on this but in the end I think my settings give the best detail while mitigating aliasing and bringing out detail without too much digital interference
It seems Samsung dialed up the Sharpness on the default setting to create a super sharp 'cut' to images then dialed it down with the Digital Noise Filter...the result, a blocky, flat, detail-less image... Turning off the Filter gives you back the detail of HD and then turning the sharpness down until the background noise deteriorates to a point without blurring facial features is the best way to get a super image IMHO. You can go to 5 of 10 on the sharpness but then you lose definition and the image especially facial images become blurred as if viewed through a softening filter.
Now the pro's and cons'...
Pros:
Stylish, not some wonky silver futuristic chrome crap with a stand from space
Excellent Blacks, probably the best I've seen on any HDTV LED LCD
No Clouding or Flashlighting at all (this was very pervasive on my other TV)
- I always think the TV is off now when there is a fade to black - AWESOMENESS!!!
Very crisp sharp picture once "dialed in"
Nice 'through the window' effect - due to small bezel and forward thrusting stand, 60" in your face even at 10 feet - sweet
Bright and vibrant colors
Better motion and less artifacting (screen door effect than previous TV)
Hate soap opera effect, luckily can turn off
Size is perfect...the thickness, who cares, looks better than my 'ultra thin' from the front is all I care about, plus I'm on the stand
Cons:
Somewhat smallish viewing angle. My guess is about 30 degrees to either side from eye level center screen before picture starts to fade (no biggie head on)
Not an IPS panel like my other Samsung edge lit TV, loved that feature but I guess its a sacrifice necessary for the Direct lit full array, I'll take the Direct lit since I don't watch my TV at an angle
Issue with Xbox 360 and HDMI / HDCP handshake - had to turn off display discovery on Xbox and all is fine now - otherwise signal might not be recognized as it was passed through receiver
Slight purplish edge trailing on small number of instances, mainly in dark scenes, only notice it if I'm being super anal and look for it
Other than that I'm happy with the TV and it's price bang for the buck
I'm still pissed my other Samsung died so early but what are you gonna do...made in Tijuana says it all
Note to new users...you NEED to calibrate this TV properly, regardless of what you read about the picture out of the box being 'perfect', it needs tweaking, but once you're there.. it's awesome
