AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXEH6000 Owners' Thread
Official Samsung UNXXEH6000 Owners' Thread - Page 23
post #661 of 2545
Originally Posted by PlasmaPZ80U View Post
CNET calibrates their TVs to 40 fL and then measures black levels and they measured .01 fL for the EH6000 and .005 fL for the D630. So, that's where I got the twice as dark figure from.
Just keep in mind that if CNET reviewed the 2011 model with an SQ02 panel they were reviewing an S-PVA, while in CNET's EH6000 review they mention "off-angle viewing was among the worst in the lineup" > very likely it wasn't an S-PVA panel in their EH6000 review.
So CNET could have vary well measured blacks twice as deep on the 2011 review, but If you actually compared them when both had S-PVA panels they would probably measure much closer.
post #662 of 2545
Finally picked up my 60EH6000 tonight. I turned off all the extra processing and am using backlight 12 and brightness 45, color 40, warm1, sharpness 16. Still playing around.
First off, it's so amazing to have no edge bleed/ flashlighting. That stuff bothers me more than anything. I'm loving the blacks as well, so much better compared to the LG 7600.
I do have Uverse, which is like the worst compression you can get for cable, so PQ looks a little worse than the 55" LG 7600 I had before.
So far I watched parts of Black Swan, Another Earth, and Horrible Bosses on HBO. Also the new episode of New Girl, some Storage Wars, and Boardboard Empire.
Boardwalk Empire is the only thing I've watched so far where I noticed pretty bad purple tinges on motion, like scenes where someone wearing a black/dark suit walks across the shot with a light background. I noticed the purple tinge (it's like on the edge of things) quite a few times on this show, but haven't really noticed it on anything else yet. Is this odd?
My second gripe is motion in general, things could be smoother, less jittery, I'm still experimenting with the Motion Flow stuff but haven't found the best setting yet.
post #663 of 2545
do you have a sharp panel? check the sticker on the back of the TV under "Version"... if the first letter is H, it's a sharp panel
Yes, HS01. How does the HS01 stand up to the other panel types?
P.S. my software version says T-MX9FAUSC-1016.0 and the most recent on Samsung's website says 1012.3
post #664 of 2545
Hello! Longtime no post.
I just got the 65EH6000 last Monday. I am coming from a 62HM196 Toshiba 62 DLP and there is a definite difference. Blacks are better, slightly crisper image. Overall quite a good improvement. Uniformity seems like a big step up - especially on dark screens. The few "glowy" parts I had (bottom center primarily and some more slight glowing in the upper left), were almost completely gone after a gentle massage with a microfiber cloth and a couple days of use.
The ONLY issue I am struggling with is viewing angles, as others are apparently discussing. I am at 9.5' from the TV sitting directly in front of it, and I can literally LEAN in either direction and see fading - significantly so. When I go from sitting in the middle to laying on the couch with my head to one side - it's obvious.
I am guessing if I had a bigger room it would be less of an issue, because the "sweet spot" would be wider further back. As it is, I am tempted to bump up the color and contrast a bit to compensate for viewing off angle. We used to have 8 people in here playing Rock Band on my big TV. I guess those days are over - or at least without comments about my TV being faded...
Is this just something I have to get used to?
Version No: MH01
post #665 of 2545
the issue you describe is specific to the sharp panel
Figures... does the Hxxx panel have any pros compared to the other panels or is it too hard to say?
post #666 of 2545
I returned my UN46EH5000 (TS02 panel) in hopes of getting a LN46D630, but it looks like I waited too long and no more are available in my area at either Best Buy or Sears. I'm now deciding whether I should use this opportunity to upgrade to the UN46EH6000 instead of just picking up another UN46EH5000. Of course, I'm only looking at Txxx panels (Samsung S-PVA). Is the picture noticeably clearer on the EH6000 with fast moving scenes and how does the PQ compare in general? Has anyone here had both the EH5000 and EH6000 and which do you prefer and why?
I've never had the EH5000 but had the 6000. I liked the motion resolution on the EH6000. Did not see any noticable blur. It all depends on what you like though. I put my AMP settings on smooth as I don't mind the S.O.E. As far as PQ goes I think it might be about the same as the 5000, maybe a tad better. I did not like the PQ on the EH6000 for many reasons. 1. Purple/Violet tinge on everything grey, white, and black. 2. Yellows did not look right at all. 3. Discolored vertical sections on left and right side. 4. reddish skin-tones
Alot of people like their set and you shouldn't base your decision on my observations. They still have the EH6000 on display at Best Buy. Check it out and see how looks for you.
It's too bad you can't find the D630. It has better PQ than the EH6000 by far but does have some juddering issues that you might not like. It's not too bad and seems to do it only on a handful of channels but it is somewhat distracting when it happens (only happens on fast moving and panning scenes). I've had my D630 for a week and I'm still trying to figure out the best settings to get rid of the judder/stuttering. I was told by a Best Buy Store Manager that even though they don't currently sell the LNxxD630 they can still order one. Takes about 7-10 days. Check their website and see if it's still available to order online.
post #667 of 2545
Need a little help from those with experience purchasing from Amazon. I purchased a 60" EH6000 off of Amazon on Tuesday morning, I had debated going 65" but the 65 was from a contracted company and the 60" was from Amazon with the schedule delivery and free shipping option as I am a PRIME member. Scheduled the delivery for today, Friday, took the day off work and was anxiously awaiting my 9 AM appointment to have the television delivered. I got an email from Amazon at 4 AM day of delivery saying that the item has not been shipped and may be delayed. Keep in mind when I ordered on Tuesday they had 12 left in stock. I monitored the price and quantity throughout the day and Amazon had sold out of its allotment by that evening and it was now being sold through third party vendors. I was thankful I purchased my order when I did! However, it looks like I will not be getting my TV on the scheduled delivery day, took a day off work, and was only advised of this delay 5 hours prior to delivery. Has anyone had similar experiences? Anything that can be done?
Thank you for the help/advice. I am just blowing off steam but looks like this is going to cost me an additional vacation day to have the TV delivered.
post #668 of 2545
Just picked up a UN46EH6000 from Best Buy, version TS02 (same version and screen size as the 5000 series I had before). I will be unboxing and setting it up in the evening and fully calibrating it tomorrow. I opted for it over getting another 5000 series because setting AMP to Custom with Blur Reduction at 10 and Judder Reduction at 0 on the store display model really improved motion without any SOE (this being true even though the source feed was pretty mediocre). I didn't bother with LED Motion Plus, but I might turn it ON on my actual set if I can get enough light output with it on (30 fL to 35 fL is good for my viewing environment, which is dim to dark). I just hope there are no dead/stuck pixels or flashlighting/clouding/bright spots. I am expecting some vertical banding, though, something which all Samsung S-PVA panels have to some extent.
You won't have to worry about flashlighting/clouding/bright spots on the EH6000. Does have the vertical discolored sections on the left/right of the screen. Not really that much of an issue though. Enjoy your set.
post #669 of 2545
Do you notice any trailing/smearing on dark or high contrast areas/objects in games or movies?
post #670 of 2545
purchased an open box un46eh6000 and it didn't come with the 4 screws to screw the tv to the actual stand.
can anyone help me determine what size they are? would greatly appreciate it. been watching it with the tv just sitting on the stand (no bolts)
thanks
post #671 of 2545
thanks
I think they are like this > http://www.ebay.co.uk/itm/Samsung-LCD-TV-pedestal-stand-fixing-screws-set-of-4-/330791973824?pt=UK_Home_Garden_LivingRoom_TV_Furniture&hash=item4d04bcf3c0
Not sure what size they are though...
Here is the UN46EH6000 parts list http://www.samsungparts.com/Products/Parts_and_Accessories/UN46EH6000FXZA/Default.aspx
Edited by chicolom - 9/30/12 at 5:10pm
post #672 of 2545
UN46EH6000, Panel Version TS02, Build Date August 2012, Firmware Version 1014.1
Native On/Off Contrast Ratio: 2,700:1
Native ANSI Contrast Ratio: 2,700:1
(Calibration done with i1 Pro spectro and CR measured with unprofiled C6 colorimeter)
Couple of things. First, very new build date and newer firmware than Samsung has for download now. Just saying.
Second, would you mind providing some links for someone like me who might want to use the same tools as you for calibrating? My set looks good now but I'd enjoy making it even better. Thanks.
post #673 of 2545
MY TV TURNS ITSELF ON AFTER I TURN IT OFF!!! Pulled the trigger on a UN60EH6050F. Set it up 3 hours ago and i loved the tv!!! i came from a 55NX720 Bravia. So i took it out, set it up, played with it for 3 hours,fell in love with it, and when i went to shut it off it immediately turned back on. It does not cycle on and off!!! Its only when i hit the power button on the remote or the TV. otherwise it just stays on as it should.But none of the settings are being saved. All the calibrations i made are set back to default as soon as it turns itself back on frown.gif If i unplug it it obviously shuts down but as soon as i plug it back in it turns itself on!!!! I checked all the settings, i did a reset to default and i upgraded the firmware from 1011.1 to 1012.3 but no luck. I also took the batteries from the remote and no such luck either. I bought the tv from a costco supplier for $900 New in box. He gave me a reciept and told me i have a 30 day warranty with him but i havent called him cause its almost 3 am LOL. but i will call him tomorrow. Anyway what do you guys think. I love the tv but this issue is killing me!!! Thanks and i love this forum
post #674 of 2545
nope its not in store mode and i did the plug and play thing 3 times to make sure:(
Edited by cd5tuner - 10/2/12 at 9:11am
post #675 of 2545
Originally Posted by doggghouse View Post
The Geek Squad came by and did my free television calibration this morning, so far I'm pretty impressed with the new PQ! smile.gif I didn't have time to do some independent testing, but according to their graphs, my UN60EH6000 calibrated very nicely.
(BTW these settings are for a well-lit room.)
Picture Mode: Movie
Color Temp: Warm2
Gamma: 0
Backlight: 16
Contrast: 98
Brightness: 43
Color: 48
Tint: 50/50
Sharpness: 6
White Balance:
- R Offset: 25
- G Offset: 27
- B Offset: 25
- R Gain: 12
- G Gain: 25
- B Gain: 25
All of the special options turned off (ex. smooth motion)
Thanks for the post. I just recently picked up the un46eh6000 to replace an older 720p 37 inch Panasonic Plasma. I calibrated the Samsung using the DVE HD Basics test patterns. The result looks much better than the default settings. I'm very happy with the picture quality. I'm by no means an expert in the area of calibrations, and am unsure about some of the settings (see below). However, the result after calibration looks very good to me.
btw....I used HDMI #2 port. Not sure if using this vs HDMI/DVI #1 makes a difference?
settings I used:
Mode: movie
Backlight-16 (I'm not sure about this setting. 16 is just a random guess)
Contrast-98 (I used your 98 setting and my calibration shows that it worked fine for me. Seem's very high though. My Samsung 50 inch plasma is 78)
Brightness-43
Sharpness-22 (I tried 6, but the test pattern seemed blurry. 22 sharpened up the test pattern without adding any false edges, etc....looked natural)
color-48
Tint G50/r50
Advanced settings::
colorspace -auto (Not sure what this setting does)
White Balance: (left at default...not sure how to assess whether or not adjustment is needed).
R-offset 25
G-offset 25
B-offset 25
R-Gain 25
G-Gain 25
B-Gain 25
Gamma : -1
Dynamic contrast off (?)
Blacktone off (?)
Flesh tone 0
Motion lightning off
Picture options
Color tone warm1
size 16:9 (not sure what this actually needs to be: 16X9 or fit)
Digital noise off
HDMI level normal greyed out
film mode Auto (?)
Auto motion clear 5 Blur Judder 5 (Not sure how this should best be set?)
Led off
post #676 of 2545
Returned my set and got my money back...went to Best Buy and picked up an open box UN60EH6000 (no crappy costco model smile.gif jk). It was returned because the previous owner couldnt fit it anywhere in his house LOL. So got it for 1199.99!!!!! This set is awesome...to me it looks better than my previous KDL55NX720!!! andiseem to prefer the thin bezel over the monolithic design. The only thing ive noticed is the slight purple ghosting but it is minimal. I have graet uniformity and no banding. Im using Btaylors settings with Dogghouses white balance.
post #677 of 2545
HS01...is this good or bad??
post #678 of 2545
Have you tryed any video games yet with the brightness set from anywhere from 0-50 and noticed any smearing on dark objects when panning the camera?
post #679 of 2545
I think i saw some vertical or digital or backlight? banding on a grey sky in the in the infamous 2 demo on the ps3.
post #680 of 2545
yes same panel version.Does anyone know if the firmware 1014 will be released on samsungs website?
Edited by Borvok - 10/2/12 at 8:48pm
post #681 of 2545
My brightness is set to 22, my input is an xbox360s and i played minecraft, max payne 3, halo reach, hitman absolution sniper challenge,, streamed some hd episodes of vampire diaries, my little pony, and a 1080p avi of batman begins. From all this all i could really notice was the very very slihht purple trailing during minecraft and vampire diaries...very rarely while playing max payne 3. During the xbox360 logo on startup i dont see any banding whatsoever neither on the hitman absolution logo screen which is just a blood red screen with the words hitman on it in the middle.
post #682 of 2545
post #683 of 2545
Whoa can someone tell me how to delete my multiposts??? Sorry!!! Damn lagging phone:D:D
post #684 of 2545
is this bad or normal for my panel...it gets worse if i set my xbox to standard and the tvs black level to low frown.gif I noticed it an hour ago when i popped in mw3. Its visible on the netflix logo screen, and any type of grey shades and earth and skin tones just slightly. And then theres the top inch or so down wich always remains slightly or more darker. Did i get another bad set?? should i haul it back to Best buy (3 hour drive for me) or should i go through samsung warranty??? starting to fall out of love with this thing...dammit frown.gif
post #685 of 2545
in case you cant see it (which i doubt) its the horizontal banding...but the top inch is darker >frown.gif
post #686 of 2545
http://www.youtube.com/watch?v=RKjxZ4pEktA&feature=plcp Heres another video of smearing brightness is set to 46,Its in the resident evil 6 demo at the beginning of the leon part.
post #687 of 2545
Well my luck with samsung tvs is ****! LOL at least their warranty and customer service is cool. I just found out i have a Samsung Authorized repair shop in a 7 min walking distance from my apartment. So i walked down there, showed him the pics and he told me that my panel is definitely faulty. I took my reciept from BB with me we were 15 min on the phone with samsung customer service and i got my service ticket already...the only weird thing is that my warranty on the ticket says im covered parts and labor till 2014!! even though my reciept says 10/1/2012 LOL
post #688 of 2545
Are you using AMP Custom: BR 10 and JR 0? With those settings, my set has minimal blur/ghosting. In fact, most of the time I don't even see it.
Yeah set to br 10.
post #689 of 2545
"--Picture menu
Mode: standard
Backlight:10-20
Contrast:94
Brightness:46
Sharpness: 0
Color:50
Tint:50/50
Advanced settings submenu
Color space: Auto
Gamma:+3
Dynamic contrast: Off
Black tone: Off
Flesh tone: 0
Motion Lighting: Off
Picture options submenu
Color tone: Warm1
Digital Noise Filter: Off
HDMI black level: Low
Film mode: Auto greyed out
Auto motion plus: Custom
-- Custom settings:
Blur reduction: 10
Judder reduction: 0
LED Motion Plus: Off xbox reference levels standard, ps3 limited sometimes i also see a slight red tinge on the edge of the smearing/trailing effect. lowering low level red white balance reduces this but just makes it green.Maybe its the new firmware that fixes the smearing?
Edited by Borvok - 10/3/12 at 4:37pm
post #690 of 2545
I'm getting the 60" version delivered tomorrow. I know several people have posted their settings in this thread. I really do apologize but this is not an area of expertise for me. Can someone recommend me the best settings for a naturally well lit room? Any help is appreciated. Thanks guys.
