Originally Posted by
Paul H
IMO, Stickers are light blockers with negligible weight. It says they're reusable, so I'll reserve judgement. Just want to get the dam things!
+1
My personal edumicated guess is that the "stickers" are actually made of an opaque version of the same material that some higher-end smartphone screens are covered with at the factory.
It looks like its glued on but its the type of plastic they use that lets it stick without needing an adhesive.
The only thing I would worry about is, once peeled off, putting it back on would leave air bubbles that
might be visible on the inside.
Whether they would be visible once the brighter screen(s) becomes your center of attention is another matter.
Kudos to the CEO for putting out to the public that he had a pre-release issue with his sole product.
Whether he just isnt politically savvy or has a lot of confidence in the end product is yet to be seen but his attitube bodes well.
+1 on the poster at the end with the comparisions.
I, for one, am also waiting to see if this is the 3D solution for me that wont require buying another projector and I will also decide based on reviews here at AVS.
Have already gotten a hold of every single BD 3D ISO of every 3D movie released worldwide so far in anticipation of using an ST1080 with an Oppo 93
