From the SMD "comments" section in the
5/15/2012 Blog:
Rearranged for better Q&A clarity:
George: 1. Colors (compared to HMZ or compared to anything you tried, TV, PJ etc).
Jeffrey: 1. Colors seems to be a bit worse than my LED/LCD laptop screen. But still more than good enough for watching movies/playing games etc.
George: 2. Blacks (compared to TV/PJ, whatever).
Jeffrey: 2. Not great, Black is dark gray. It also seems to be having some light bleeding issues on the sides.
George: 3. Sharpness of the edges (is text uniform across the screen, legible in the corners)
Jeffrey: 3. Text is very sharp, good readable. Only the corners are a bit out of focus. If you focus on them they are also sharp.
George: 4. Perceivable distance to the screen compared to HMZ-T1 (is this really 100" at 10' away, or smaller/larger?)
Jeffrey: 4. Don't have the HMZ-T1, So can't judge on that. But it looks like a big screen.
George: 5. 3D pop effect in movies in 1080p. (don't care about 720p until scaling is added)
Jeffrey: 5. Depends on the movie. For some movies it is hard to see, and some are just amazing with floating stuff towards you and everything. For PC games you can sometimes adjust the effect to make it stronger. I liked the 3d effect in Unreal tournament 2004 (in combination with iz3D) the most. Especially flying with the redeemer
George: 6. Were you able to play a game in 3D in 1080p 30Hz top-bottom full frame mode? How was the image quality? How was framerate (tolerable for fps games like Call of Duty or not)?
Jeffrey: 6. Didn't got that mode to work yet (Have to play around with programs on my laptop, to get different modes to work). NVidia Vision 3D detects it but only for bluray playback. 3DTV Play from NVidia does not seems to work right now (all options disabled). I personally prefer 1080p 3D SBS 60Hz (half resolution). Its 60Hz and still looks very good.
George: 7. Is focus easily attainable? Do you just put it on your nose like regular glasses and everything's immediately in focus, or do you have to adjust it to a sweet spot... and if so how big is it?
Jeffrey: 7. At first you really have to get used to the HMD. You can adjust 2 slides for your pupil distance. After that it is just putting it on and have fun. Ofcourse there is a 'sweet spot', where you can see most of the screen perfect. But you can still see everything good when moving the HMD around. You can even shake your head while the screen stays good
