Hello,
I am new to the forum, but I have a question that after searching I still couldn't answer, so here goes...
I have a Runco IDP-852 CRT projector that has always been hooked up via S-video. Well I got the crazy idea that I wanted to run 16:9 and a better picture so I tried to hook up my old bluray player to it. On the back of the projector I have RGB HS VS (Horizontal and Vertical Sync). I tried going from the Ypbpr to the RGB and the picture is great except for the dreaded green tint that overpowers the picture. I bought BNC connectors to RCA and use monster cables to to run from RGB to the Ypbpr, I have changed out the cables, tried different connectors and still cannot get rid of the green. I tried a different bluray player (both were Samsung), turning colors up and down, no luck. I connected to the projector VGA to RGBHV cable and the projector worked fine, but I don't want to leave a laptop hooked up to it. If I look at the front, it looks like green is very well lit, but the red and blue are not. I would assume that one of the red or blue is loose, but they are not. Does this have something to do with Sync on Green that I have been reading about or am I forgetting a setting?
Any thoughts?
Any thoughts?
