AVS › AVS Forum › Audio › Audio theory, Setup and Chat › How to aim in-ceiling speakers
post #1 of 4
I have Sonance 623R in-ceiling speakers. I use these as surrounds in a 5.1 system with Ascend RAAL Towers and a Sierra-1 NrT Center. (...I know in-ceiling speakers are not ideal, but it's what I have to work with.)
I can aim the woofer and tweeter individually. I'm wondering if it's recommended to aim the speakers directly at the listening position, or aim it at the back wall "to get a more diffuse sound", as the manual describes it.
A lot of my listening it 2 channel music. The in-ceilings are only used for blu-rays.
post #2 of 4
Throw in some movies and experiment for what works/sounds best in your room. Take your time and enjoy with your final decision.
post #3 of 4
I have my tweeters pointed towards the main listen position. Neither my Vife or I have any complaints.
I have the in-ceilings two feet away from the walls, and do not think pointing the tweeters away from the MLP would be beneficial.
post #4 of 4
Dolby Labs recommends aiming the speakers at the listening position - the surround channels are mastered for positional audio sound effects and cues, so you want directional sound, not diffuse.
