AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Random moving White speckles
post #1 of 3
So I am in the process of hooking up and tweaking my new system which includes a Epson 8100 pj, a onkyo TX-SR309 avr, a sony BDP-BX58 and everything is hooked up with cables form the latest hdmi standard. So here is my problem when I run the bdp though the avr I get random white moving speckles, sort of like a white noise, I have verified all cables are in proper working order, and even had a new avr sent to me (which did slightly improve the number of white speckles). Also when I hook the BDP straight to the pj there is no issue, so I am fairly confident that both the pj and the bdp are in proper working order.
The longest run of hdmi cable I have is from the wall to the pj it is 25' and is 28awg, cl3 rated. All other hdmi cables are Rosewill - Pellucid HD Series 6'
I have tested the issue with deep color on and off, and found that there is less of a problem with deep color in auto mode. Last night I did notice that one hdmi cable I have has ferritic cores and maybe I need to put them on all the cables, b/c the problem did seem to get better is that cable was run form the bdp to the avr.
thoughts and ideas would be very helpful, thanks.
post #2 of 3
Replace the 25' cable with a 22-24 AWG high speed HDMI cable and your sparkles (white speckles) should go away.
Ferrites won't do a thing to improve your signal and might actual degrade it slightly.
Leave deep color off. It requires a higher bit rate and offers questionable improvement in the picture considering the source is encoded at 24-bits/pixel.
post #3 of 3
And if you can't easily replace the 25' cable with a thicker one, an HDMI extender would be the next option...
(no experience with this first-hand - but you're look for a powered version)
Jeff
  Back to Forum: Home A/V Distribution
