AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Recommendation for replacing a Denon AVR-4306
post #1 of 3
I'm thinking about replacing my Denon 4306 with something newer. I'm looking for something that supports the latest HDMI (and works well with a Samsung LCD and Sony Blu-ray), has Audyssey (or similar auto-equalization) and does 110w 7.1. My speakers are Polk Monitor Series II (60s for the fronts, 40s for the surrounds and a CS2 for the center). And for the budget, I'd like to keep the receiver under $1000. So, what should be looking at?
post #2 of 3
The 3312 streets for $800. If you can pony up to $1250, the 4311 is the way to go and gets you into Audyssey MultEq XT32.
Here is the deal thread on the 4311:
http://www.avsforum.com/avs-vb/showthread.php?t=1388717
Here is the thread on the XX12 models, the first three posts are very helpful:
http://www.avsforum.com/avs-vb/showthread.php?t=1334369
post #3 of 3
You might want to check out the last few weeks of the 4311 thread to see what people have to say about it. Its filled with mostly happy campers.
http://www.avsforum.com/avs-vb/showthread.php?t=1274153
