So I've been searching the internet for a couple days about this issue. I have found similar threads to my issue (like this one or this one where people complain of WMC resizing to 1024 resolution) - but nothing that matches exactly what I am seeing.
I have a Vizio TV with an Onkyo TX-NR809 receiver and an AMD Llano A8 based HTPC. I keep WMC up all the time in Full Screen mode.
My HTPC goes into sleep mode when not in use which in turn will put the Onkyo in Standby mode after about 30 minutes. Following no signal from the receiver the TV will auto-off after another 10 minutes.
Generally, I shut the TV off manually, which uses CEC to auto shut off the receiver as well. I then just let the HTPC fall into sleep mode.
The problem is that a good portion of the time when I turn everything back on (use a remote keyboard to bring HTPC out of sleep and then TV power on also sends CEC to turn on Onkyo) my Windows Media Center has been minimized away from full screen.
Here is an example pic of what it looks like:
The box in the front is Realtek HD Audio Manager which is also auto-popping up on ocassion - another issue I am trying to deal with. But what I am trying to show is WMC up in the top left of the screen.
As you can see, it isn't technically "minimized" because it doesn't have a border around it. It is as if it was full screen on a smaller res display that then got resized - but it stuck.
The current fix is usually to minimize and maximize (sometimes twice) to get it to go back normal, but even then I sometimes have some strange drawing issues within the program. So, I really need to shut it down and reopen it.
I've tried several different configs within my receiver settings, but the issue is so random it is hard to test when it is happening and when it isn't. It seems to happen at least half the time I bring the devices out of sleep/off/standby in the morning, but I can't seem to reproduce it by manually cycling them all.
Does anyone have any ideas what might be causing this?
thanks.
thanks.
