Even after doing my background work I was just wondering if what I found out about this PJ is true. (It is HDMI 1.3 not 1.4 a)
All I want to be able to do, is hook it to a 3D player like a Panny 210 and view 3D Blu-ray.
The problem is some online reviews make it sound like because it can't do 1080p 3D that you must get a 3D converter like the Optpma 3d-XL.
But from my understanding it seems as long as you can set the source device like the Panny 210 Blu-ray player to output 720p this projector should give you 3D(Real 3D not the converted 2d to 3D), is that correct ? You would only need a Optoma 3d-XL if you had a source device that could not be set to 720p and you needed the 3d-XL to downscale 1080p to 720p for you...
I was just hoping someone here has this pj or could bouble check what this pj can do 3D wise for me.
You can put a 1080p 3D movie in the Panny 210 and set it to output 720P 3D can't you ? I thought you could do that with most all Blu-ray players and even cable TV boxes ?
...Thanks
