AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › Sound card recommendations?
post #1 of 2
I am in need of a new sound card for my laptop so that I can use REW. Only requirements are that it have a good line in and line out connection. My laptop is a 6 month old Samsung NP-RV510 purchased from bestbuy for under 400.00. Can anyone recommend an external sound card for under 75.00?
post #2 of 2
I assume REW is Room EQ Wizard
http://www.hometheatershack.com/roomeq/
If all you need is a mono mic input, then
http://www.geeks.com/details.asp?Inv...SB2CH&cpc=RESX
should do the job.
If you want stereo in/out with line level and SPDIF in/out, this one is hard to beat-
http://www.geeks.com/details.asp?inv...-EF-BP&cat=SND
Both should work fine in common linux distros.
I have had good luck with this one in Ubuntu and Audacity
http://3btech.net/saus8usb20ex.html
Lots of I/O ports on that one
  Back to Forum: HTPC - Linux Chat
