I used Monitor Asset Manager to read the EDID. There are a couple interesting things here. For one, the EDID reports the display size as being 32.1 inches, when in fact it's 40. Is that significant?
It also lists its native resolultion as 1360 x 768. It has 4 detailed timings with the typical HD resolutions listed. Anybody know what's going on here?
Monitor
Model name............... SC32FI
Manufacturer............. SEK
Plug and Play ID......... SEK3201
Serial number............
Manufacture date......... 2011, ISO week 20
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 710 x 400 mm (32.1 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.637 - Ry 0.325
Green chromaticity....... Gx 0.286 - Gy 0.609
Blue chromaticity........ Bx 0.148 - By 0.058
White point (default).... Wx 0.279 - Wy 0.289
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-68kHz
Vertical scan range...... 59-61Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1360x768p at 60Hz (16:9)
Modeline............... "1360x768" 85.500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1090 1125 +hsync +vsync
Detailed timing #2....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #3....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.030 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #4....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.180 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96 kHz
AC-3 2-channel, 512k max. bit rate at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 2.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 2/28/2012
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0051
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,AB,01,32,00,00,00,00,14,15,01,03, 80,47,28,78,0A,14,38,A3,53,49,9C,26,
0E,47,4A,A1,08,00,61,40,95,00,B3,00,01,01,01,01,01,01,01,01, 01,01,66,21,50,B0,51,00,1B,30,40,70,
36,00,BA,88,21,00,00,1E,00,00,00,FF,00,0A,20,20,20,20,20,20, 20,20,20,20,20,20,00,00,00,FC,00,53,
43,33,32,46,49,0A,20,20,20,20,20,20,00,00,00,FD,00,3B,3D,0F, 44,0F,00,0A,20,20,20,20,20,20,01,B1,
02,03,27,71,50,01,02,03,04,05,06,07,90,11,12,13,14,15,16,1F, 20,26,09,1F,07,11,07,40,83,01,00,00,
66,03,0C,00,20,00,80,02,3A,80,18,71,38,2D,40,58,2C,46,00,40, 84,63,00,00,1E,8C,0A,D0,8A,20,E0,2D,
10,10,3E,96,00,13,8E,21,00,00,18,8F,0A,D0,8A,20,E0,2D,10,10, 3E,96,00,C4,8E,21,00,00,18,FA,1C,80,
18,71,1C,16,20,58,2C,25,00,C4,8E,21,00,00,9E,00,00,00,00,00, 00,00,00,00,00,00,00,00,00,00,00,BF
