AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Blackout Curtains - recommendations
post #1 of 3
Can anyone here recommend a good set of blackout curtains. I have a 50" Samsung plasma and the glare is really bad during the day. I don't want to spend a fortune though. I've heard decent things about the eclipse brand. I have one big window about 84" across that I need to cover. Just wondering if these blackout curtains really do the trick?
-Guru
post #2 of 3
-Guru
Get whatever curtains youd like..Eclipse and others sell blackout panels you can add to the back of any curtain.
Or you can just go to a fabric store and select a thicker material and DIY.
post #3 of 3
Find a local seamstress, they can make you something better, than you can buy off the shelf.
