Originally Posted by
rogo
The issue with the cyan tracking -- however major or minor one thinks it is -- is not yet fixed.
airgas1998
and the pulsing that is inherent in ALL of them to a certain degree. i had four sets and they all had the pulsing issue. which to me is way more of an issue then the cyan tracking.
these are the known flaws with this set, but if you aren't bothered by the pulsing issue, and you don't notice the slight color inaccuracy issue, this is
generally considered to be the best set on the market currently. it has far fewer issues and complaints by owners than the next best set, the sony hx959.
just be sure to buy it form a place that will accept returns as the return rate on both of these are on the high side.
