AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Strip of staticy/moving pixels across the top of my ST30?
post #1 of 4
I decided that I wanted to see if there was any signs of burn in since I've been play alot of Call of Duty lately lol, so I made this image to load on my 360 and at the top of the screen I noticed that theres a strip of pixels going horizontally across the whole screen that seem to be moving....you wouldn't notice it at normal viewing distance especially since you don't look at things that are a solid color but I just wanted to know if anyone knew what that was. My set is a 42 inch ST30 and it took up about an inch and a half of screen space going across the entire screen. I couldnt notice it as much on other colors. This is the picture I used.
http://img14.imageshack.us/img14/4835/63875833.jpg
post #2 of 4
That's normal same thing happens on my 58" S1.
post #3 of 4
it is called dithering and it comes with any plasma package it souldn't be a problem if you aren't trying to fake an IMAX experience 12" from the tscreen.
post #4 of 4
I just thought it was weird that its only showing on a perfect strip across the top of the screen rather then the whole image since the image is a solid color.
