Originally Posted by
kaushal98
Thanks apw2607. Would you know if anything from BDP570, LG BP620 or Panasonic DMP-BDT220 would support that?
Hi again.
Right, I stand corrected. Maybe something got patched recently in the last firmware, because I'm sure I tried this before ...
In any case, I found a MKV AVC test file with embedded subtitles here (TEST III) ...
http://forum.xda-developers.com/showthread.php?t=1054962
It played perfectly on the Sony. Audio was present (DTS), and english subtitles were displayed.
So there you go, the new 2012 Sony's do support subtitles embedded in MKVs.
Media info from test file FYI >
* * * Media Inspector 0.7.443 file analysis report.
* * * Media Inspector is ©2011 by Diego Massanti -
http://mediainfo.massanti.com
* * * MediaInfoLib by Jerome Martinez -
http://mediainfo.sourceforge.net
Created on: Jun 7, 2012 3:43:49 PM PDT
Report for file: iguana.monsi.1080p.bd9.sample.mkv
General / Container Stream #1
Total Video Streams for this File.................1
Total Audio Streams for this File.................1
Total Subtitle Streams for this File..............1
Video Codecs Used.................................AVC
Audio Codecs Used.................................DTS
SubTitle Codecs Used..............................UTF-8
Available Sutbitle Languages......................English
File Format.......................................Matroska
Play Time.........................................1mn 0s
Total File Size...................................81.0 MiB
Total Stream BitRate..............................11.3 Mbps
Encoded with......................................mkvmerge v2.9.7 ('Tenderness') built on Jul 1 2009 18:43:35
Encoding Library..................................libebml v0.7.7 + libmatroska v0.8.1
Video Stream #1
Codec (Human Name)................................AVC
Codec (FourCC)....................................V_MPEG4/ISO/AVC
Codec Profile.....................................High@L4.1
Frame Width.......................................1 920 pixels
Frame Height......................................1 080 pixels
Frame Rate........................................23.976 fps
Total Frames......................................1442
Display Aspect Ratio..............................16:9
Scan Type.........................................Progressive
Color Space.......................................YUV
Codec Settings (Summary)..........................CABAC / 3 Ref Frames
QF (like Gordian Knot)............................0.192
Codec Settings (CABAC)............................Yes
Codec Settings (Reference Frames).................3
Video Stream Length...............................1mn 0s 143ms
Video Stream BitRate..............................9 569 Kbps
Bit Depth.........................................8 bits
Video Stream Size.................................68.6 MiB (85%)
Video Stream Language.............................English
Audio Stream #1
Codec.............................................DTS
Codec (FourCC)....................................A_DTS
Audio Stream Length...............................1mn 0s 146ms
Audio Stream BitRate..............................1 510 Kbps
Audio Stream BitRate Mode.........................CBR
Number of Audio Channels..........................6
Audio Channel's Positions.........................Front: L C R, Side: L R, LFE
Sampling Rate.....................................48.0 KHz
Bit Depth.........................................24 bits
Audio Stream Delay................................7ms
Audio Stream Size.................................10.8 MiB (13%)
Audio Stream Language.............................English
Subtitle Stream #1
Language..........................................English
Format............................................UTF-8
Codec ID..........................................S_TEXT/UTF8
Codec Info........................................UTF-8 Plain Text
