Yes, plays fine. No issues.
* * * MediaInspector for Mac - Version 2.0, build 896
* * * ©2012 by Diego Massanti
* * * MediaInfo Lib by Jerome Martinez
* * * Raw File Report for London.2012.Olympics.Opening.Ceremony.BBCHD.1080i.HDTV.DD2.0.H264-dm8000_Sample.ts
General
Complete name : /Volumes/MKV Media 2/Media/London.2012.Olympics.Opening.Ceremony.BBCHD.1080i.HDTV.DD2.0.H264-dm8000_Sample.ts
Format : MPEG-TS
File size : 64.4 MiB
Duration : 29s 664ms
Overall bit rate : 18.1 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=48
Codec ID : 27
Duration : 29s 640ms
Bit rate mode : Variable
Bit rate : 17.0 Mbps
Maximum bit rate : 40.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.329
Stream size : 60.2 MiB (94%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 4
Duration : 29s 760ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 698 KiB (1%)
Language : English
