Originally Posted by apw2607
The MKV I had the following DTS audio info:
General / Container Stream #1
Total Video Streams for this File.................1
Total Audio Streams for this File.................3
Video Codecs Used.................................AVC
Audio Codecs Used.................................DTS-HD / DTS / PCM
File Format.......................................Matroska
Play Time.........................................2h 19mn
Total File Size...................................32.4 GiB
Total Stream BitRate..............................33.2 Mbps
Audio Stream #1
Codec.............................................DTS
Codec (FourCC)....................................A_DTS
Audio Stream Length...............................2h 19mn 50s 5ms
Audio Stream BitRate..............................2 596 Kbps / 1 510 Kbps
Audio Stream BitRate Mode.........................VBR
Number of Audio Channels..........................6
Audio Channel's Positions.........................Front: L C R, Side: L R, LFE
Sampling Rate.....................................48.0 KHz
Bit Depth.........................................24 bits
Audio Stream Title................................Lossless
I'm not sure what DTS "HD" really is according to the file inspector. When I playback that file on the S590, my receiver shows "DTS High Resolution" ....
I need to find a proper DTS - MA file to test I guess.
Audio Stream #1
thanks,
does this cinavia affect only US players?
does it affect only bluray discs or files also?
i create my mkv's using 'pavtube bytecopy' from original blurays, would these be affected?
![Planet Earth: The Complete BBC Series [Blu-ray]](http://cdn.avsforum.com/d/d0/50x50px-ZC-d03751c8_B000MRAAJM-51vOcFKASRL.jpeg)
). I checked out the three streaming players that I care about and BD playback and everything seems decent and as expected: Netflix with 1080p/CC/bitstreamed DD+ 5.1 with a PS3-like info overlay activated with the DISPLAY button (I love that), VUDU with bitstreamed DD+ 5.1 and Amazon with bitstreamed DD 5.1. The Amazon player GUI is pretty sucky and its playback start time is probably the slowest I've experienced. It's bearable, but hopefully it'll get updated in the future. The Netflix GUI is much more responsive than the BDT220's, though it does lag behind in updating the title info pane (the PS3 player doesn't but it can't bitstream Netflix DD+).
