AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Sony BDP-S590 and BDP-390 Thread
Official Sony BDP-S590 and BDP-390 Thread - Page 70
post #2071 of 3994
Originally Posted by johanverschuren View Post
Playback problem on the BDP-S390 with the Van Helsing Blu-ray disc.
The Van Helsing Blu-ray disc gives a system hang-up during playback. During the playback of the Blu-ray disc the screen suddenly freezes and there is a complete hang-up of the BDP-S390 Blu-ray player. The player does not respond to the remote control any more and the only way to solve the problem is to disconnect the power from the AC outlet. I have the latest firmware version M11.R.0422 for the BDP-S390 sold in Europe. I have reported this problem to the Sony Support Team in Europe and I hope that Sony Japan can resolve this playback problem with a new firmware update.
Have you tried disabling Deep Color to see if that has an impact?
post #2072 of 3994
Deep Color is now set on auto. So if the source has 16 bit code it will be engaged. I can disable Deep Color to see if it has any impact. Sony Japan has to look into this matter because under no circumstances the player should lock-up regardless the settings of the Blu-ray player.
post #2073 of 3994
There is NO reason to leave Deep Colour ON/AUTO. Nothing in the Audio/Video rhelm of today uses it. Leave in OFF.
post #2074 of 3994
Turn off any features you don't need on the player, including "Auto Display", in the System Settings.
If the player locks up again, try holding down the power button on the player (not remote) until it goes off, instead of simply pulling the plug (which is probably not a good idea).
post #2075 of 3994
Can anyone confirm to me if the S590 can indeed play mp4 video files off a data DVD disc?
post #2076 of 3994
Yup.
post #2077 of 3994
Originally Posted by apw2607 View Post
Yup.
Thanks, I just wanted to make sure it will read mp4 videos off a DVD instead of just USB devices like some other players.
post #2078 of 3994
How do I make my Sony s590 a DVD region free player?
I'm in Oz I bought this player assuming - like my last Sony Bluray player - that it would be DVD region free.
But it's locked to DVD region 4. I've searched around and found no remote control hacks for this model. Earlier model DVD region hacks for Sony Bluray players use a brand of universal remote (the All In One brand) that I don't have. I own a Logitech universal remote.
Any tips?
post #2079 of 3994
Very difficult to do with logitech because of the complexity of getting several pronto hex codes into the remote. I recommend you get a one-for-all. They can be had for as little as $3 on ebay in the US and perhaps Oz as well. Just about any of the basic or comfort line HERE should work fine. UEI (maker of one-for-all) also makes many cable, satellite, OEM and store brand remotes. So you may already have one and not know it. There are literally hundreds of remote models made by UEI which will work. If you find a specific model and aren't sure if it will work, post back and I can tell you if it will or not. Also post a link to the hack procedure so I can translate the codes correctly for your model. Another benefit of having a one-for-all is you can add every possible command for all your devices because many are missing from the logitech database.
post #2080 of 3994
Thanks. I'll have a look around.
post #2081 of 3994
Wow, that would be a huge help. Is there a specific remote on ebay you would recommend for price and function?
I'm assuming the hack only works for dvd's, but as a longshot is there a way to hack for blu rays as well?
post #2082 of 3994
I've never tried the hack on sony myself, nor do I have any foreign DVDs, so I can't say. But I do know these remotes. The models vary by what part of the world you are in. Here in the US, the models below can do the hack using DVD code 0533 or 20533 depending on the access method ([2] means 20533 and anything else is 0533). The cheapest and easiest to find is probably the Comcast 1067BX3 If you can't find any of these elsewhere, PM me. I have plenty. HERE's how to do the hack. The magic key is also the S, Setup, or P key. Warning: Spoiler! (Click to show)
Code:
Offset       Access Method   Signature       Remote  Processor
[2]     30603060        15-100  S3F80
[2]     30853085        15-133  S3F80
[2]     30853085        15-134  S3F80
[2]     30853085        15-135  S3F80
[VCR]   RSL6RSL0        15-1994 S3C80
[DVD]:[VCR]     RS50RS50        15-2103 S3C80
[DVD]:[VCR]     R6H0R6H0        15-2104 S3C80
{DVD}   RTS0RTS0        15-2107 S3C80
{DVD}   RSL1RSL1        15-2116 S3C80
[DVD]   RSFFRSF0        15-2133 S3C80
[DVD]   RS80RS80        15-2138 S3C80
[DVD]   10101010        15-2144 HCS08
[DVD]:[VCR]     10631063        URC-10820 B00   HCS08
[DVD]:[VCR]     11781178        URC-10820N      HCS08
[DVD]:[VCR]     ECL0ECO0        URC-3440        S3C80
[DVD]   HVC0HVC0        URC-4080        S3C80
[LDP]   O5F0O5F1        URC-5650        S3C80
[DVD]:[VCR]     6_806_80        URC-601X        S3C80
[DVD]   PVR0PVR0        URC-6131        S3C80
[DVD]   10361036        URC-6690 Hybrid HCS08
[DVD]:[VCR]     10631063        URC-6820 B00    HCS08
[LDP]   O5F0O5F1        URC-7200        S3C80
[VCR?]  EO40EO40        URC-7541        S3C80
[DVD]:[VCR]     10751075        URC-7555        HCS08
[DVD]:[VCR]     EBV0EBV0        URC-7560        S3C80
[DVD]:[VCR]     EBV0EBV1        URC-7562        S3C80
{DVD}   10621062        URC-7780 Stealth 12     HCS08
{DVD}   11311131        URC-7781 Digital 12     HCS08
[DVD]   C7L0C7L0        URC-7800        S3C80
[DVD]:[VCR]     30293029        URC-7940        S3F80
[DVD]:[VCR]     30293029        URC-7950        S3F80
[DVD]:[VCR]     6_806_80        URC-801x        S3C80
[DVD]   EKA4EKA0        URC-8040        S3C80
[VCR]   KAMEKAM0        URC-8060        S3C80
[DVD?]  10261026        URC-8203        HCS08
[DVD]   10211021        URC-8206        HCS08
[2]     11691169        URC-8350        HCS08
[DVD]:[VCR]     6_806_80        URC-881x        S3C80
[DVD]:[VCR]     10631063        URC-8820 B00    HCS08
[DVD]:[VCR]     11781178        URC-8820N       HCS08
{DVD}   CPT0CPT0        URC-8910        S3C80
{DVD}   CPT0CPT0        URC-9910        S3C80
[DVD]   NAK0NAK0        URC-9960        S3C80
[DVD]   KASAKAS0        URC-9960B01     S3C80
[DVD]   ATL0ATL0        Atlas4 ATL0     S3C80
[VCR]   CS400102        Atlas4 CS400102 SST
[DVD]   10251025        Atlas5 1025     HCS08
[DVD]   30003000        Atlas5 3000     S3F80
[DVD]   30323032        Atlas5 3032     S3F80
[DVD]   30333033        Atlas5 3033     S3F80
[TV]    SA_7SA_7        Atlas5 SA_7     S3C80
[DVD]:[VCR]     BAL0BAL0        Balboa-Dolphin  S3C80
[VCR]   OEM4OEM0_1      Cat48-Anthem    S3C80
[VCR]   OEM4OEM0_2      Cat48-Outlaw    S3C80
[AUX]   CS300103        Comcast 1058 jp1.1      SST
[AUX]   CS301009        Comcast 1067 jp1.2      HCS08
[2]     30393039        Comcast 1067BX3 jp1.3   S3F80
[AUX]   CS300105        Comcast 1068 jp1.1      SST
[DVD]   30463046        Cox URC-7820B   S3F80
30       [??VIDEO]      10381038        Dreambox V5 URC-39940   HCS08
30       [AUX]  ETPSTPS0        Dreambox.       S3C80
30       [DVD?] ESPBESP2        DreamboxKeyboard
30       [AUX]? OLVAOLV0        DreamboxV2      S3C80
[VCR]   MIL0MIL0_1      Millenium4      S3C80
[VCR]   MIL0MIL0_2      Millenium4_b00  S3C80
[2]     30043004        Motorola DSR551 URC-2050        S3F80
[VCR]:[AUX]     LATLLAT0        Mundial4        S3C80
[DVD?]  30483048        Pace DStv PVR URC-3989  HCS08
[DVD]:[DVR]     31793179        RCA RCRP05B     S3F80
17       {DVD}  TCE0TCE0        RCU810  S3C80
29       [VCR]  DSS0DSS0        REM400-B00      S3C80
[VCR]   DSS1DSS1        REM400-B01
[VCR?]  OEM3OEM0_1      Replay-V1
[VCR?]  OEM3OEM0_2      Replay-V2
19       [VCR]:[DVD]    T6D0T6D0        Toshiba CT90047 S3C80
[2]     30023002        Vizio URC-66700ABA      S3F80
[2]     30273027        Vizio VUR8      S3F80
[Y]     BINJU   Slingbox - JU   S3C80
[Y]     BINPK   Slingbox - PK   S3C80
[Y]     BINPL   Slingbox - PL   S3C80
[Y]     BINRV   Slingbox - RV   S3C80
(Just ignore the stuff that makes no sense. I'm too lazy to clean it up right now.)
post #2083 of 3994
I'm thinking of buying the BDP-390 sometime in the future.
Can the player read mkv files off of Data-BDR's?
post #2084 of 3994
BDP-S390 and NAS
Hi Guys,
Just bought the S390.
With the help of this forum I have managed to get the 'HomeStream' to work, using the Bravia format.
Has anyone managed to hook a Seagate Goflex NAS drive to the S390 via the Lan cable?
I can only read m2st and mp3 files from the Seagate Goflex.
Avi and mkv are, not supported.
I don't like leaving my PC on all the time to watch films via HomeStream.
BTW Netflix is working fine.
CM
post #2085 of 3994
Hi Guys,
CM
post #2086 of 3994
Hi folks,
I have a relatively straight forward question, that hopefully can be answered - I have tried looking through previous posts, but there are quite a lot of them.
Does Netflix UK work on a BDP-390 based in the UK? I've been trying to find an answer for hours, but all that I can find is "It should work".
Thanks in advance
post #2087 of 3994
Originally Posted by Coffe Mug View Post
Hi Guys,
CM
MKV files with mpeg 4 AVC should play fine. VC-1 or mpeg2 needs a bit of tweaking. MKVs are just containers for something else !
post #2088 of 3994
I don't think you can tweak VC-1; these files need to presented in an M2TS container to play back on a Sony BD machine.
post #2089 of 3994
Hi Guys,
Just bought the S390...
It looks like the Seagate supports UPnP and the Sony supports some .avi and .mkv files. You won't have the flexibility of Homestream/Serviio, which can transcode or remux, but some files in those formats should work if the codecs are compatible (mpeg-4 for mkv and Xvid for avi). Are you able to see the mkv and avi files in the directory listing when you browse video files on the Seagate from the player?
post #2090 of 3994
I have contacted the Sony Support Team in Europe and they have asked me several questions about the hang-up problem of the BDP-S390 player. One of the questions was if I use a HDMI port with ARC (Audio Return Channel). The BDP-S390 is connected with an Audioquest Pearl HDMI interconnect to a Sony KDL-40EX650 LCD TV using a HDMI port with ARC. If the ARC function is not working good this could stop the communication over the HDMI bus. I do not think the settings of the player can be the problem of the hang-up during playback of the BDP-S390 player. The hang-up moment is random during playback of the Van Helsing Blu-ray disc. So far this is the only disc which causes the player hang-up problem.
http://www.hdmi.org/manufacturer/hdmi_1_4/arc.aspx
Edited by johanverschuren - 11/7/12 at 12:25am
post #2091 of 3994
Thanks for reply,
Yes I can see all the files, but get the corrupted/ un supported message.
post #2092 of 3994
Originally Posted by CraigScot View Post
Hi folks,
Thanks in advance
I have Netflix and Lovefilm running on my S390.
I'm in the UK.
post #2093 of 3994
Have you actually tried turning off ARC in both the TV and the receiver to see if that helps?
Bugs in the implementation can cause problems whether or not it "should" work.
post #2094 of 3994
I use the term tweak loosely .... MKV VC-1 -> M2TS
post #2095 of 3994
Help with fast forward on .mpg streaming video
Hi all,
I haven't found a direct answer to this on the site so I figured i would ask direct. I'm using the S590 to stream a .mpg video from an HPServer (Home Server) and using just the remote control that came with the unit. It doesn't seem to have any fast forward or pause functions from the remote. I was previously using popcorn hour in one room and an LG BlueRay in another and both funtion fine with the mentioned functions. Is there any fix to this?? Thanks in advance.
post #2096 of 3994
Sony should look into this matter. The BDP-S390 player should work correctly regardless the use of a HDMI with or without ARC. On an other AVS thread I have seen a posting about a similar hang-up problem with the BDP-S790.
post #2097 of 3994
Thanks for reply,
Sounds like the codecs being used in your files are incompatible. Open some of your files in a program such as MediaInfo, which can display details about the codecs being used in your files. This information will help to determine why specific files are not playing from your NAS without transcoding/remuxing from Homestream/Serviio,
post #2098 of 3994
Hi
Does BDP-S590 keep spinning the disc all the time when disc is inserted? Even when playing internet video or listening internet radio? Or when player is in XMB menu?
post #2099 of 3994
I noticed this with my 580, so I think it may be common. It got to the point it wad so loud that I put my Wii on top of it as a paperweight to hush the vibration and humming.
post #2100 of 3994
Originally Posted by tomalo View Post
Hi
Yup. Think so. 790 does it too. Annoying !
