Originally Posted by
Foxbat121
H.264 streams through DLNA just fine but you need the proper software on your DLNA server to make them streamable. Xvid or not is up to your PC how to serve them. You need somekind of software (either a codec pack or special DLNA server software). I can stream BD ripped in mkv with DTS-HD audio intact directly to my player.
For H264 ? I dont think so. The 590 can stream those without any trans-coding enabled on the DLNA server (so long as the files are not DRMed).
Stick the file on a Hard drive/USB stick and try it in the front usb slot ... see if it plays.
Again though folks when you say files dont play, its much better to provide details of the file using a program like Media Inspector. It provides all the info you need when trying to troubleshoot playback issues. So many audio and video codecs, profile level, versions, resolutions, frame rates, bit-rates to consider.
E.g. Media info output.
General
Complete name : /Media/iTunes/test.m4v
Format : MPEG-4
Codec ID : M4V
File size : 54.7 MiB
Duration : 4mn 8s
Overall bit rate : 1 842 Kbps
Movie name :
Album :
Album/Performer :
Performer :
Recorded date :
Encoded date : UTC 2008-02-20 23:42:05
Tagged date : UTC 2011-10-14 07:31:25
Writing library : Apple QuickTime
Copyright :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 4mn 8s
Bit rate mode : Variable
Bit rate : 1 542 Kbps
Maximum bit rate : 4 006 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.167
Stream size : 45.7 MiB (84%)
Language : English
Encoded date : UTC 2008-02-20 23:51:22
Tagged date : UTC 2008-02-20 23:51:48
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 4mn 8s
Bit rate : 255 Kbps
Maximum bit rate : 327 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 7.58 MiB (14%)
Language : English
Menu
Language : English
Encoded date : UTC 2008-02-20 23:51:48
