Hey guys. I'm semi new to the whole video codec arena but am fairly adequate with converting movies and such. I bought a Sony S390 and am using the Asus N66U wifi router which has a external harddrive connected to it. I have the blu ray player upstairs and most movies are "File is corrupted or unsupported". Ive read through most of the posts regarding the s390 being picky with codecs but still am bewildered or unsure as to why one movie will play and the other will not. When I look at the one movie which does work in G-Spot it doesn't show any codecs of any sort....
However, the movie that does not work has codecs in the Video section of Gspot. Here's the data from MediaInfo regarding the two movies, one works , one doesnt.
This one WORKS:
General
Complete name : J:\VIDEOS\Looper.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 4.44 GiB
Duration : 1h 58mn
Overall bit rate mode : Variable
Overall bit rate : 5 342 Kbps
Movie name : Looper 2012 By 3Li
Writing application : Lavf52.94.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 58mn
Bit rate : 5 096 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Variable
Frame rate : 23.864 fps
Minimum frame rate : 12.000 fps
Maximum frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.307
Stream size : 4.11 GiB (93%)
Writing library : x264 core 112 r1834 a51816a
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0 / me=dia / subme=2 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / weightb=0 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=5096 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1h 58mn
Bit rate mode : Variable
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 42ms
Stream size : 326 MiB (7%)
This one DOES NOT WORK:
General
Complete name : J:\VIDEOS\Idiocracy.mp4
Format : MPEG-4
Codec ID : isom
File size : 3.79 GiB
Duration : 1h 24mn
Overall bit rate : 6 438 Kbps
Movie name : Idiocracy
Xtra : WM/MediaClassPrimaryID
Video
Format : AVC
Format profile : Baseline@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 1h 24mn
Bit rate : 6 288 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.127
Stream size : 3.69 GiB (97%)
Encoding settings : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=6288 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 24mn
Bit rate : 160 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Stream size : 96.4 MiB (2%)
I honestly cannot figure out what the difference is between the two of them other than the difference I noted when viewing it in G-Spot. Any ideas would be greatly appreciated!
