There is no inherent problem with Auto, the problem is that Auto is usually defendant on the EDID sent back by your display, and many times that can be incorrect, or you might get back the EDID for a receiver in between the two devices, and that will be different. The reason to avoid Auto is that it might incorrectly select RGB, which you don't want.
For picking between 4:2:2 and 4:4:4, the easiest way is with a copy of Spears and Munsil. They have a nice write-up about it here:
http://www.spearsandmunsil.com/artic...olorspace.html
I also use the chroma plate and multiburst patterns to select one. With the plate, you will see the edges get darker and it should be bright all the way to the edges. With the multiburst, the fine vertical line pattern will be too dark if it is incorrect usually. I wouldn't worry about it really, since if your display handles 4:2:2 or 4:4:4 worse than RGB, the usual issue is a loss of fine chroma detail. When using RGB with this Sony, the issue is that you're losing a ton of contrast range as colors will be blown out (for example) and you won't have as much dynamic range to the image, which is much worse than a slight loss of chroma detail.
So pick 4:2:2 or 4:4:4, not RGB and not Auto, at least until this is fixed. Those two are correct, any other setting from the player is wrong.
![Planet Earth: The Complete BBC Series [Blu-ray]](http://cdn.avsforum.com/d/d0/50x50px-ZC-d03751c8_B000MRAAJM-51vOcFKASRL.jpeg)
And good to have all those apps back.
