AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Budget subwoofers discussions, opinions and questions thread
Budget subwoofers discussions, opinions and questions thread - Page 35
post #1021 of 1657
For a subwoofer that looks an awful lot like a dome tent. eek.gif My reference was indeed to the ES250 series - I really don't know much about the SUB150p.
post #1022 of 1657
It has gotten quite a bit of buzz since it went on sale at Newegg for $175. Everything I have read about it has been really good. Its a 10" 300rms and looks like a heck of a deal right now. Its only on sale until tonight though. Supposed to be more accurate than the F12, go roughly just as low and has twice the power for $25 or so less.
post #1023 of 1657
Originally Posted by Pete7874 View Post
Doesn't it take more effort/power to put a larger driver in motion or to reverse its motion?
Theoretically, yes. But the electromagnetic forces of the motor dwarf the inertial forces of the mass of the cone and stiffness of the suspension by a few orders of magnitude, so in practice it doesn't matter. Think of a skateboard powered by a 1,000 pound thrust rocket engine. You can quadruple the size of the skateboard and not notice any difference.
post #1024 of 1657
Are you serious?
http://lmgtfy.com/?q=HSU+VTF-2+MK4
Maybe he tried to google all three at once???
post #1025 of 1657
http://www.avhub.com.au/images/stories/australian-hifi/reviews/2011-05_to_12/2011-11/jbl_sub150p_subwoofer_review_lores.pdf
post #1026 of 1657
OK, that's funny Bill! Having dragged a few overpowered bikes, the thought of that much thrust on any kind of skateboard was somewhat appealing.
post #1027 of 1657
I have a power question. I have a Denon 1713 which is pretty modest for wattage per channel. Should I be concerned about wattage for the sub-woofer overtaxing it.
post #1028 of 1657
The sub has its own amplifier so your receiver power rating is irrelevant. It is not drawing any power from the receiver.
Unless you have a passive sub with no amplifier.
post #1029 of 1657
So I went to check out the JBL at Fry's yesterday and while I was testing it the sub sounded like it was not handling well. Perhaps it was just their floor model. The speaker sounded like it was "chuffing" and rattling. WIsh they had the F12 to compare it to. I'm starting to think I should just borrow the tools and go back to the DIY route and get a better sub for the money. Ugh...
If I did do a DIY for less than $200, what would you guys recommend? Or is this questions for another thread in the DIY forum? Apologies if that is the case.
post #1030 of 1657
Most ported subs will chuff and maybe even rattle when pushed too hard. That mean's it's just not capable of reaching that volume in that space.
post #1031 of 1657
No worries. If you are considering DIY though it would be better to post in that forum.
post #1032 of 1657
The reasons for that could go on and on. If it sounded good at a reasonable volume then that would give you a decent idea. If you are willing, have the tools and the know how you should be able to build a sub for $200 that would put all of these mentioned to shame.
post #1033 of 1657
I really doubt that.
Al
post #1034 of 1657
Al
Specifics?
post #1035 of 1657
Al
Never built your own sub have you? LOL
For IslandStylin, start here: http://www.parts-express.com/cat/speaker-components/4
post #1036 of 1657
I haven't built my own, but I know those Dayton HO and HF series subwoofers with an amp to go with them can result in a sub that you'd have to spend a lot more for to buy from a speaker/sub vendor. If I had any woodworking skills at all and the tools, I'd do it in a heartbeat smile.gif
post #1037 of 1657
Get a cabinet from them...or look on CL/Bay for a cheap sub that may or may not work and use the cabinet. You can find busted subs all the time... wink.gif
post #1038 of 1657
Originally Posted by batpig View Post
I'm not sure I agree with that -- the PB1000 is sitting there right at $500 staring you in the face. It should be a good bit better than any of the $300-and-under subs.
Its not. The RW12 is as good. Or atleast close enough imo not to be worth another $200. And since the pb1000 is about the only thing at $500 that makes it a dead zone. Unless you can name something that really is a good bit better than the rw at $500. This is of course a very general appraisal.
Color me skeptical that the RW12 is as good as the PB1000. I may be biased but I simply trust SVS to built a great sub much more than Klispch. And the "close enough to not be worth another $200" is obviously pretty subjective. Is the Outlaw LFM-1 Plus (just to throw one out there) really that much better than the SVS to be worth another $150? You can play that game endlessly...
The SVS is legitimately flat to 20Hz, with a -3dB spec of 19Hz as opposed to the 24Hz spec of the Klipsch. And SVS subs always bear out their specs when tested by independent reviewers, so I believe the specs & graphs as posted by SVS.
The Klipsch may come close in absolute low end extension and maybe even have a touch more max output, but there is no way it's as clean as the SVS. It simply can't match the bandwidth linearity of the SVS or the low distortion. In many reviews (both user reports and the Sound & Vision test) it has been reported to be muddy at its limits (which, to be fair, any budget sub will be) and not that musical. For example, from the S&V review we see quotes like, "The sub's tonal quality was a little boomy, however, and it sometimes blossomed into resonance when hitting certain notes. It delivered lots of good bass but occasionally some not so good bass", and "It tackled the lowest notes and played them, not with the best fidelity, but with lots of energy. Mid and upper frequencies were more controlled, but the tonal quality was sometimes muddy. The snap in the bass line was obscured by some port noise, so the power of the note was there, but not always the enunciation. When really cranked, distortion was evident."
While the SVS PB-1000 hasn't been independently reviewed AFAIK, its predecessors the PB-10 NSD and ISD have been. The thing I think you are overlooking is the stuff past the on-the-surface FR plots, especially linearity and distortion. In the S&V test of the Klipsch, it delivered a ton of output but the "Bass Limit" test had it maxing out at 86dB at 20Hz with 10% distortion.
Now compare that to the PB-10 NSD, tested at Secrets. It put out 100+ dBSPL at 25HZ with less than 1.3% THD. The review goes on, "Plotting THD+N vs. Frequency, with 50 Hz set to 100 dB at 1 foot, yielded the graph shown below. Distortion stayed below 3% from about 22 Hz all the way up to 200 Hz. Again, this is pretty amazing performance for a 10" driver."
Secrets also tested the prior PB-10 ISD, and found similar results. Click on that link and just look at that ground plane measurement! 19-150HZ +/- 1dB (!!) with a 104dB dynamic compression limit. In the THD test, it put out 94dB at 20Hz with 8% THD (amp limited) and 97dB At 22Hz with only 2.7% THD! Quoting Secrets, "These distortion and bandwidth linearity values are simply outstanding. Note the amplifier limited the output at 20 Hz - 22 Hz, and the distortion at 22 Hz was only 2.7%!"
Remember, the Klipsch RW-12d couldn't even crack 90dB at 20Hz without topping the 10% THD threshold.
There is no reason to think the PB-1000 will not put up the same kind of results (or better). And let's not forget, although it may not be important to many users, that the SVS subs are flat up to 200Hz+ on the upper end, whereas the Klipsch has an upper -3dB spec of 120Hz. This could be valuable to those integrating the sub with smaller satellite speakers, but is also another indication of the linearity of the SVS products.
So the bottom line is that while the Klipsch may match (or even exceed) the SVS in raw output in the 25-80Hz range, the SVS will both dig deeper AND do it with better linearity and less distortion. If the goal is just to get the maximum output for movie effects for the dollar, I think the Klipsch is a great option, especially because you can get two for just a little more than the single SVS, but the SVS is going to deliver "cleaner" bass and really be able to hit down to 20Hz easily in room. It's really a question of priorities, but I don't think it's really in doubt that the PB-1000 is a superior subwoofer.
post #1039 of 1657
I have two CHT SS 18.1 sealed subs that I'm not happy with the frequency response roll off. They just have to be EQ'd too much. There will be an upgrade one day in my future (but not soon). Turns out the box interior on the CHT subs is the perfect size for the Dayton HO 18", and the estimated response is much better. What would be better still is if the LMS Ultra 18" was a good match. But I don't want to look at that spending yet wink.gif
post #1040 of 1657
+1
There have been enough people to talk about how while they liked the RW-12d for HT, they felt it a little boomy for music. And my son has the RW-10d. It's definitely a decent sub for the price I got it (close to $200), but I can't imagine either that the Klipsch RW series is comparable in SQ to the SVS.
However, I am biased as an EX owner, and would recommend the Plus over the PB1000, but only because I would think it a good bet it has more max SPL. But in a small to medium room? And after Jim's experience? It definitely seems like the PB1000 is tough to beat at $500, particularly with SVS's 5 year old total coverage warranty and excellent reputation for service. And you can bet that the port on the PB1000 won't be falling off and rolling around inside the sub during shipping. LOL
post #1041 of 1657
Oh yeah, thanks for reminding me... In the midst of my tirade I forgot to mention the final advantage of SVS having a reputation for simply the best customer service and support in the biz.
I don't doubt that the Outlaw is actually better BTW. Just making a point about the "for a little bit more you can get X" game.
post #1042 of 1657
I completely agree that the pb1000 is superior. I didnt know how superior until reading your post. Good info. Its still questionable as to whether its worth $200 more. That's a lot more when you are talking this price range. Of course that all depends on the individual.
post #1043 of 1657
Superiority depends on the circumstances. The RW-12d could handle much larger rooms than the PB1000 if I had a small room, I would go with the PB1000, but anything larger and its bound to get lost. I think the RW-12d will have more than just a slight output edge over PB1000.
post #1044 of 1657
Right, that's why I said it was a question of priorities. I would agree that two RW-12d will have a LOT more output capability than a single PB-1000. If I had a big room and a not-big budget, and just wanted to get as much raw output as possible for HT.... and was willing to sacrifice a little bit of sub 25Hz extension and "cleanness" to do it, then I thin $600 spent on two RS-12d's makes a lot more sense than spending $500 on a single PB-1000. They will provide a lot more "slam" and output to fill the room, and it's worth sacrificing the sub 25Hz to get that massive output in the 25-80Hz range, which is really the happy zone for many movie effects.
My main point was to counter the assertion that the RW-12d was "as good" as the SVS, and to point out that the PB-1000 is a demonstrably superior product in some key areas, namely extension (both on the low and high end), bandwidth linearity, distortion, and customer service.
post #1045 of 1657
Point taken. But to keep things n perspective I was speaking on value at the time not specifications. What brought the whole thing up was that I had said that there was a bit of a dead zone at the $500 mark. And I did say specifically that it was my opinion that the 1000 was not worth the extra $200 in such a tight budgeted category. Your point of getting 2 rw for another $100 just seems to back up my original assertion. If someone came out from the start and said they had $500 to spend and had a small room and wanted the most accurate sub they could get then I would recommend the 1000. But that would be about the only time.
post #1046 of 1657
Newegg has the Klipsch RW-12d on sale again for $299.99 with free shipping!
Al
post #1047 of 1657
Oh gosh so hard to resist!
post #1048 of 1657
Al
Saw that earlier this morning and grabbed one. Was debating between this and the JBL but as I've read and from firsthand experience, better to just go straight for the end game rather than the multiple upgrade path. This is so overkill for my condo.
post #1049 of 1657
I have a 3400 cubic foot room. I was set on a set of PB1000's but the more I read the more I am leaning towards the Klipsch RW-12d. I obviously want good sound but I also like to listen to movies and music loud.
Any input would be appreciated!
JT
post #1050 of 1657
JT
I currently have a Rythmik FV15HP and my previous sub was a RW-12d. For 3 bills the Klipsch is an absolute jewel of a subwoofer. If I had not had the funds available for the Rythmik I would have ordered a 2nd Klipsch and would have been quite happy. It's an excellent sub for the money and I have no problem recommending it.
