Originally Posted by
Bond 007
Sounds respectable. I would not shy away from it but that doesnt convince me that it is clearly better than the rw for music or movies for that matter. My worthless impression is that they are very similar with the rw going a little lower. If the CSX was more like $250 I might be inclined to look at it a little harder but with them being the same price or $20 different I would still go with the rw. I am glad that you brought the Cadence up though. If the rw ever sells out it may be the next great bargain.
When I was considering what sub to buy I picked the Cadence over the Klipsch, not because it sounded better, but, because I feel that the build quality of the Cadence is better than the Klipsch. I can't prove that but came to that conclusion from all the material I read for both subs. It's just my opinion. In my opinion, the Cadence looks better too. The sound quality difference in the low end doesn't matter to me.
As I've said, I ended up with a used Jamo SUB 650 that I'm completely satisfied with because it has more connection options than the Cadence. Why I was woried about that, I don't really know.
Al
