AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Budget subwoofers discussions, opinions and questions thread
Budget subwoofers discussions, opinions and questions thread - Page 68
post #2011 of 2778
Let's get back to the technical aspects. Here is the measurement for the CSX12:
Here is the measurement for the Lava LSP12
It's the same type of peaky midbass response.
So, when Jim writes,
Originally Posted by JimWilson View Post
A peak in the mid-bass region often denotes a sub that gets classified as being "one note". That's something quite well known.
For that to be true, then the Cadence sub would also be a one note sub. The Cadence sub review he wrote clearly refutes that generality. So either he has changed his mind about the Cadence, or this generality doesn't work. It can't be both.
post #2012 of 2778
I should also add, here is the NXG NX-BAS-500 measurements from Sound and Vision, another subwoofer that Jim likes that has a peaky midbass response:
So here is another sub that Jim reviewed, and liked, that counters that generality that a peaky midbass response indicates a "one note" sub. I just don't see how one can predict that the Lava sub will be bad based on these two other experiences.
post #2013 of 2778
Bond 007: room is approx 3400 cu ft, 90% movies. Read previously that dual PB-1000 would be increase of 6db (don't recall if that was over the single PB-1000 or the single PB-12?), so just wondering if dual Lava LSP-12 would be better considering it's the cheaper choice?
post #2014 of 2778
And that's something you truly don't want to mess with. So no cerveza's either I take it?
On Friday, I had a double (3oz and I'm two hundred pounds) and twenty ounces of beer and my blood pressure was up fifteen points the next day. Sunday it was down ten points. I haven't taken this morning's readings.
I'm thinking a half pitcher of some decent tap with the occasional dinner out as from personal readings I can see a direct correlation to the blood pressure rise but it quickly falls back starting the next day. I'd hate to think I'm playing Russian Roulette with stroke and a beer but my understanding of these things say, as long as things are smooth and healthy inside the arteries, no concern of blood clots developing. My inclination, unless a special occasion, I just have to let it go all together as a three shot cocktail, neat, will drive my blood pressure up fifteen points. Boo-hoo me.
post #2015 of 2778
3400 ft^3 is a pretty large space for a single PB1000, so duals are really a better choice for you. As Transmaniacon said, dual LSP's will probably have more output into the lower 30's, but the PB1000 will dig much deeper. It all depends upon what you want to achieve, and how much money you have available of course.
post #2016 of 2778
+1. My HT space is ~3,400 cu.ft. and I would definitely recommend duals of any moderately-powered sub for a space that size.
post #2017 of 2778
For a room that size, the PA-150 might be a better choice. It won't dig as deep as the PB-1000, but will have about the same, if not better, 30Hz+ output as the Lavas, and should beat them from 20-30 as well.
post #2018 of 2778
+1
This also gives you the option of adding a 2nd, matching PA-150 later on if you want more output, which might be easier than trying to find spots for two more LSP12s (for a total of four). Generally, it is best to use the same sub in multiple sub configuration setups; makes it easier to integrate them all.
post #2019 of 2778
My apologies if alcohol is a struggle for anyone wasn't thinking about triggers smile.gif
Best!
post #2020 of 2778
Where are the LSP12's found for $170??
Sent from my Galaxy Nexus using Tapatalk
post #2021 of 2778
On Lava Subwoofer website.
post #2022 of 2778
Originally Posted by jlpowell84 View Post
My apologies if alcohol is a struggle for anyone wasn't thinking about triggers :)Best!
Alcohol's not a struggle but my stupid blood pressure is. That was my sole point. Thanks for the thought. Rest assured, there are no triggers here. Six months ago I would have been right there with a pic of my favorite adult beverages but as one gets older, issues such as blood pressure creeps into the picture. Choices have to be made. I love the taste of a few good cold ones. I enjoy the relaxing benefit of a three shot cocktail of my favorite whiskey and then increasing blood pressure entered the picture. Boo-hoo me. tongue.gif
The benefits of high blood pressure, should one survive an event are; blown out kidneys and the ever lingering potential for stroke, heart attacks and an ever failing circulatory system; not to mention a lifetime of blood pressure controlling medication. Kinda hard to support continuing to drink alcohol when those are the alternatives.
(i was just throwing a lament in as many has been the time when i participated in such entertainment as yours and personally, I was ticked that I have to drop out of this type of fun.)
(my ale/lager of choice were/are the many and varied local brews)
Edited by BeeMan458 - 11/4/13 at 10:34am
post #2023 of 2778
post #2024 of 2778
Originally Posted by Bond 007 View Post
Yesterday's struggle was trying to watch a play-by-play of Seattle and Tampa Bay online (no cable coverage) as Tampa lost in overtime.
(Chicago beat Green Bay....Woo-hoo! That win sure messed their league up as now, here it is mid-season and the top three are all tied. tongue.gif)
Edited by BeeMan458 - 11/5/13 at 5:39am
post #2025 of 2778
Any chance anyone could post a photo of the driver or inside of the PA-150 or a link to where one may be? Can't find any online. Thanks!
post #2026 of 2778
http://forum.blu-ray.com/showthread.php?t=82738
Here are some shots of the smaller PA-120, though I would imagine things are similar.
post #2027 of 2778
Josh Ricci may have one in his review on data-bass.com, but the site is currently being upgraded.
post #2028 of 2778
I didn't want to pay more than $150 for a sub. I might could swing a little more. Is this Lava sub better than the Dayton 1200? I saw lots of reviews for the Dayton.
post #2029 of 2778
Would the sony w2500 be as good?
post #2030 of 2778
According to the owner's manual (PDF), the SAW2500 is rated as 60W RMS at 1% distortion / 100W RMS at 10% distortion, with a frequency response of 28-200Hz +/- ?dB. I'd pass on it.
The Dayton SUB-1200 is a better - and well-regarded - choice.
post #2031 of 2778
I think if you can get the Lava for $170, I would take it over the Dayton SUB1200, but both are fine budget choices.
post #2032 of 2778
Will one sound better for fps? I just got B4 and pre-ordered COD Ghost.
post #2033 of 2778
Gaming and movies are pretty similar, it will make your explosions go boom.
post #2034 of 2778
Boom is good, but I want it to sound good for my music. I listen to mostly hard core and dub step.
post #2035 of 2778
Save more money.
post #2036 of 2778
Save more money.
+1. A couple of options to consider aiming for:
- an SVS PB-1000 ($499, shipped - with free return shipping within 45 days); or,
- a Rythmik LV12R ($589, not sure if that includes shipping).
post #2037 of 2778
It's all about the Benjamins and how many of them you have to throw at the problem. Subwoofers don't care. Subwoofers are heartless. Subwoofers are dead and cold. Either one buys for performance or one lives with disappointment. A feral cat is friendlier than a subwoofer.
post #2038 of 2778
Feral cats attack people and dogs. I hear what you are saying. I guess I have to wait a long time if I got to spend more $. frown.gif
post #2039 of 2778
No on the PB-1000, and yes on the Rythmik LV12R for $589 shipped. Over all a better subwoofer.
post #2040 of 2778
I had it narrowed down to those two options and I ended up with the Rythmik.
