Originally Posted by batpig
I think you always have to take the advice in this forum with the "grain of salt" that you are dealing with hardcore enthusiasts. It's always important to keep perspective on your personal expectations and needs in relation to that context.
Thus you get some hyperbolic claims like the above. If you ask what the best $200 subwoofer is, you will be told to spend $500 or it's not even worth it.
The key is being realistic about your expectations. If your desire is to achieve movie theater quality bass, with a room that size fully pressurized with powerful output down to the low reaches of sub-bass contained in modern action movie soundtracks, then, yes, you do need to spend a lot more money. But if you just want something to go "boom" and fill in the low end at reasonable volumes in your living room, and do a much better job than that little Polk sub, then you will be fine.
This accurately summarizes my hopes/goals/expectations for this purchase.
I'm not an audiophile. Yet. But when I hooked those Monitor 70's up in place of those RM-6751's, the difference was significant and immediately noticeable to both myself AND my wife (who is ALWAYS skeptical of everything I do... and probably rightfully so hah). And I liked what I heard. We both did. A lot. So I upgraded the Center Channel. Now I'm looking to maybe do the Sub.
I'll gladly pay a hundred or so extra $$$ if it'll make a difference. Just looking for some input/advice on the best way to spend my money... and appreciate all of what I've received so far. This website, overall, is a great resource.
(Sorry for not being clear). One PS12 for $249 or two Velodyne VX11s, Which one would you prefer?. I understand that velodyne is 33 Hz to -140 Hz whereas PS10/12 is 25 Hz to 180 Hz but not sure to what extent this will affect the HT experience. Just to add, this is my first HT and never used a Sub before.
I look forward to reading your reviews over at HTS!
