AVS › AVS Forum › Video Components › Home Theater Computers › Question on BR HD Audio Playback (audiophile type question)
post #1 of 4
Note: I'm not familiar with BR audio hardly at all other than what I've tried to read. I don't do video much, but I have gotten a BR player for my Mini in order to play concert footage.... so now I have a BR audio question.
I have a 2011 i7 AMD mini.
My current audio setup has the following output options:
--HDMI to my TV (not high quality)
--Optical out to my (older Rotel) receiver which supports DTS, DD, 2.0 PCM (not HD audio). I do not use the Rotel for amplification. I use the pre out to the BAT.
--24/96 USB out to my external DAC (Benchmark) that feeds via balanced to my integrated.
For amplification I have BAT VK-300xSE
I don't care about multi-channel sound, only high-quality 2ch playback (or 2.1 if that matters). I use my Mini for playing back 24/96 vinyl rips and for playing back my pretty massive CD collection.
***My question: Which of these is the highest quality sound output from my given setup above? Based on my ears, I'm thinking it's the DTS-MA Lossless track which plays fine via VLC. I believe when I select this option the Mini is going to convert it to a 24/96 stereo signal which outputs via my DAC to my hifi setup.
I have a full disc rip of the Nirvana Live at the Paramount BR (killer performance!)
In VLC, I see the following audio options - Audio option / what I see in Media Info
2/0 - PCM S24 LE (araw) stereo 24/48
VLC can play fine via any audio output. I am guessing this is a stereo PCM bitstream at 24/48.
Lossless - DTS Audio (dts) Lossless 6ch 24/48
VLC can play fine via any audio output. I'm guessing this is DTS lossless, which my setup is going to down-mix to stereo.
3/2+1 - DTS Audio (dts) 3/2+1 6ch 24/48
VLC can play fine via any audio output. I'm guessing this is encoded DTS which my setup is going to down-mix to stereo.
3/2+1 - (undf) 3/2+1 6ch 24/48 6912kb/s
VLC errors on playback. I'm guessing this is the DTS bitstream PCM track?? I can't play this as I don't have a DTS / HD audio capable receiver.
post #2 of 4
vlc cant play dts-hd ma properly.
pcm should be the best.
post #3 of 4
Do you have any idea what codec or what method VLC is using since when I select DTS-MA it plays back fine??
post #4 of 4
it plays it like a regular dts track.
and even at that, it should be better to use your rotel's decoder rather than vlc's.
