Members,
Up-Date,
Both rear surround speakers are going to be mounted on the rear wall.
They are going to sit on Custom made speaker shelves.
The speakers will sit on "Auralex" Monitor Isolation Pads.
As large as this site is and all the members that are on it I am sure some of you have experience in this.
I need to mount {Both} of my JML Mini Utopia (59.4 Lbs) each rear surround speakers to the rear wall.
That is the only way I can do it as there is the staircase coming up into the room.
This speaker if possible mounted on the rear wall will solve the problem of location.
What I would prefer is a mount where the speaker could sit on the base plate without drilling holes in the bottom of the speaker.
I did find a mount that will handle the weight and it is by, (OMNI-Mount).
http://www.standsandmounts.com/omnim...eiling600.aspx
But as you see it would require drilling holes in the bottom of the speaker.
I also found these but they are not heavy duty enough or large enough to hold the JML Mini Utopia spkr.
http://www.amazon.com/Pinpoint-AM-40.../dp/B002UV03MW
Product Features
Weight 59.4 Lbs.
24" Tall
16" Deep
10" Wide
Thanks for any assistance you can give on this.
Terry
Take a look at this picture and you can see the starcase to the Left of the rear surrounds.
I want to mount the (Left) rear surround on the rear wall above the staircase.
Then move the right rear surround to the far right on it's stand.
Old Picture of HT .........
Latest picture of HT .......
Up-Date,
Product Features
- Fits most Bookshelf style speakers
- Adjustable side clamping design for speakers 5.5"-11" wide
- 50 lb. max weight load
- Tilt angle +/-7 degrees; swivel +/-90 degrees
- Steel construction
Weight 59.4 Lbs.
24" Tall
16" Deep
10" Wide
Terry
impressive vacuuming job too...
Mains are JM Lab Mezzos
