AVS › AVS Forum › Display Devices › Flat Panels General and OLED Technology › Best LCD/LED 50-60 inch for less than $900
post #1 of 5
My old rear projection LCD is about to go and I'd like to replace it on a budget of about $900 or less. Not interested in Plasma.
- Could care less about 3D
- Prefer LED due to reduced energy usage
- Don't care about Apps or any of that extra stuff
- MOST IMPORTANT, It must have an ability to turn that "smooth motion" stuff off, I think it is the most distracting thing watching a movie imho.
So just a cut and dry good old HDTV with no fluff or smoothing action. Let me know some ideas. Thanks!
post #2 of 5
Good luck.....
post #3 of 5
Try checking out costco?
post #4 of 5
I know you said you'd like led but if you can afford $900 you can afford the extra $12/ yr it'd cost to run a plasma instead. pn51d550 is a great choice for well under $900. That would give you 3d and a much better picture than 98% of the leds in that price range just my 2 cents
post #5 of 5
That is a good option I posted in another thread that last years best buy 55" LW5600 are $900 on sale now.
Plasma if you have a bright room might not be an option and if your that worried about power check bestbuy I know they don't to rain checks so if they don't have any more stock your SOL.
