I am running Time Warner Cable and Internet. The cable from outside is connected to a two-way splitter to send direct line to the Cable Modem and another direct line to a Radio Shack 4 way 10db splitter. These are the signals I am getting at the moment.
Cable HD Box:
In Band Quality 1 1.30dBmV 34dB
In Band Quality 2 0.40dBmV 35dB
RF Quality 9.80dBmV 24dB
Modem:
Receive Power Level
-4.9 dBmV
Transmit Power Level
43.3 dBmV
Downstream:
Power Level
-4.9 dBmV
Signal to Noise Ratio
37.2 dB
Upstream
Power Level
43.3 dBmV
I want to get rid of the first splitter and run everything through an amplifier with active return. I need to boost my signal to my TV a little more because those levels fluctuate -3 or so often. Also the Cable Modem could use a little boost as the Power level is close to -5 range. Removing the Splitter will give me back some power and I think the Radio Shack amp doesn't have any active or passive return if that matters. The other TV's connected to the amplifier aren't HD, regular cable.
I was looking into the PCT 4-Port RF Signal Amplifer With Active Return found at http://www.amazon.com/PCT-4-Port-Sig...0336584&sr=1-1
Any suggestions are appreciated, thanks.
dja2k
Cable HD Box:
Modem:
Receive Power Level
-4.9 dBmV
43.3 dBmV
Downstream:
Power Level
-4.9 dBmV
37.2 dB
Upstream
Power Level
43.3 dBmV
dja2k
also, your modem levels on your first post -4 is just fine.
