AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Correct Sub Crossover setting?
post #1 of 4
I have an older Infinity powered sub with a manual crossover dial on the back that was made for an older receiver that didn't have any options to set the crossover frequency. I am not using it with my Denon receiver and have the receiver's crossover set to 80Hz. What should the dial be set to on the back of the sub if I just want to let the receiver manage the crossover frequency?
I'm assuming I should turn it to the max frequency on the dial, but wanted to make sure. Thanks.
av_freek
post #2 of 4
yup, set it at MAX, the AVR would do the rest
av_freek
post #3 of 4
av_freek
I gather that the Infinity sub has no LFE input, only L&R RCA and possibly speaker level inputs...in which case set the crossover dial on the sub to the max.
post #4 of 4
Thanks. Yes it only has L&R RCA connections on it. Will make sure it's set to max.
