I'm not sure how this is discussed, so I apologize if it's talked about to death.
Basically, I'm looking for suggested/recommended settings for Handbrake to keep the video quality very high, but significantly reduce the file size from MakeMKV.
I'm using the nightly builds of Handbrake so I can use and save the HD audio tracks; my HTPC can't handle HD audio nor do I have a AVR that can use it either. It's more for later down the road.
I've been using the variable rate setting of 18. I'm just a bit skeptical of a 22GB file going to 4 to 6GB. My bite rates around average around 3mbps to 6mbps. I figure this keeps the file down, rather than telling it to use a constant rate of say 10mbps
Files look good when I play them, but with my colorblindness and other issues, I can't always tell how good is good. I've had some other people look for me, but I can't seem to explain how close to the original is it.
I realize every rip can be a bit different. I'm just looking for suggested starting points.
