Ok my asrock mobo is controlling my fan speed from a lowest speed of 2200 rpm to 3500 rpm if you manually turn it all the way up. At 2200 rpm the fan is very audible in a silent room, if a movie or TV show is playing it isn't really noticable unless in a very silent scene. I'm curious what everyone's cpu fan speeds are and whether they are audible. Since my cpu temp isn't getting anywhere neer hot I would really like to solve this problem at the fan level. So are there fans that don't make a lot of noise at 2200 rpm? Also another fan might not run at the same rpm at the same voltage from the mobo right? Another thing I was thinking is to maybe solder in a resister in between the mobo and fan to drop it 500rpm at all mobo setting, the mobo would still be able to kick up the rpm right? just always 500 rpm less then now.
PS its a stock llano A6 cpu fan, 70mm I think.
