Originally Posted by ctviggen
My system is way too complex for this simple idea. For Win7, I have HDMI going to a receiver but I have two monitors (projector and regular monitor). If I turn on the receiver to listen to music, all hell breaks loose and I completely lose the view on my regular monitor. I have to use a mechanical HDMI switch between the computer and the receiver to prevent this (when I'm done watching the projector, I switch the switch to an unused input). I don't want to use the projector for just normal web surfing, balancing my checkbook, doing work. Microsoft hasn't figured out that people actually use two screens. Maybe Win8 will correct this, but I'm not holding my breath.
Nope, you can get that to work without the switch. I've got the exact same setup. I use optical out for music instead of the HDMI. You do have to switch the preferred audio device to SPDIF though, but once you switch the input on your receiver to the SPDIF input, you should still retain an image on your monitor (since your receiver should no longer show up as a display device).
And actually, I think you can fiddle with your display settings and even get it to work over HDMI. You just have to manage to set your monitor to be the primary display (only display would be better). At least with the Nvidia drivers, they remember this the next time you kick on the receiver.
Nevertheless, it can be done one way or the other. No need for the switch.
