AVS › AVS Forum › Video Components › Home Theater Computers › HDMI /DVI (PC) input samsung
post #1 of 9
samsung hdmi input
why the HDMI/DVI (for PC) input can not handle sound like other's hdmi input
alll my hdmi inputs are connected...so i have to pass a long audio cable SPDF (optical )from my PC to my amplifier..............
or next to the the HDMI/DVI (for PC) input ,a little cable in the 1/8'' input.
hdmi input with no sound :what is the purpo
post #2 of 9
I am not sure your premise (that it cannot handle sound) is correct.
post #3 of 9
i have 4 hdmi input total.
1 is named hdmi/dvi........in the book and on the HDTV Samsung . no sound pass trough(t) because there is a 1/8 in audio IN beside that input.
post #4 of 9
must connect audio from PC too.
i try it no sound
so why is that? reason?
post #5 of 9
that sound input is for using DVI on that port...because DVI doesnt carry sound. if you have and nvidia card, make sure that the output in the control panel is hdmi-audio and not hdmi-no audio
post #6 of 9
i know that.........the 3 other HDMI IN have sound with my HDMI OUT of my PC.
Question: why HDMI/DVI can not pass sound
what special have that INPUT.
post #7 of 9
Did you try a different input setting on that hdmi?
I forgot what the options were, but remember I had to change mine to connect the htpc.
post #8 of 9
Not sure what exact Samsung TV you have, but you may have to rename the input to just "PC". On my PN50B650, naming it "PC" is required to have input from the HTPC work correctly. Never tried "HDMI/DVI" so I can't comment on whether that kills the sound. But I did try "STB" for the name once, and found I was getting black crush (figure only with "PC" input will it handle the reference levels correctly).
post #9 of 9
yes, that was it, "PC" rather than "STB" (on a PN50c490).
