Originally Posted by jmcguire525
FYI I have no affiliation with Omega. I owned a dual stack BenQ W6000 and tried out 3d with a Harkness silverscreen and cheap polarizers from polarization.com. I also tried using dolby lens as filters on a white screen. In my opinion the only reason to use polarization is if you get JVC projectors and filters matched to them and use a really large screen. I also think it is interesting that Runco switched from polarization on their dual stack system over to the Omega filters (Panavision).
Polarization:
-Pros: High trans% using SPAR or JVC POL filters, Wide range of comfortable glasses
-Cons: requires a silver screen, filters diminish after time, there will be ghosting and how much depends on your filters and screen
Omega 3D:
-Pros: No silver screen, minimal ghosting (should be better than any polarized setup but I will let RDJAM test that), Long life of filters, Cheaper than buying the best polarized filters
-Cons: 65% light loss (about the same as polarized unless you buy SPAR filters for 3LCD or JVC), uncomfortable glasses
Polarization:
Omega 3D:
Thanks jmcguire525 for very helpful information.
ahl (
