Here's the deets. Best bang for your buck HDMI HdBaseT extender over 1 cat5e.
The HydraConnect HDMI extender use industry standard HDBaseT technology for very reliable, long distance (330 feet - 100 meter) transmission of an HDMI connection over a single CAT5e or CAT6. Special features of the HEXT-21 are:
Very Small Size - 1 X 2 X 3 (2.4cm X 4.8cm X
7.2cm)
Only One Power Supply at Transmitter End - much simpler installation as no power supply is required behind the television
Low power -when operating the HEXT-21 uses approximately 14 watts (compared to 20 watts for dual power supply extenders)
Automatic Power Down - when the video stream is absent, the HEXT-21 powers down to less than 10 watts. Dual power supply units draw nearly 20 watts 24/7
No Adjustments Required - HDBaseT technology ensure completely automatic gain adjustments with no installer adjustments required
IR Transmission - when HEXT-21 is not used with an HSS-1 (which uses CEC for display control and does not need IR), IR signals can be sent from either the transmitter or receiver to the other respective unit
HEXT-21 is the smallest HDBaseT HDMI extender available, and in addition requires no power supply behind the television. This results in the ability to mount flat screen LCD televisions really flush to the wall.
This thing is amazing!!!! Did I mention it is the least expensive out there in good quality? List is $475 You cannot beat the deal. I have had no issues with this companies products so when this came out I chomped at the bit. I mean really, HdBaset HDMI over 1 cat5e with bi-directional ir? To me this sounds like a time to add more TV's.
Just wanted to pass this along as I think some of you could use this!
7.2cm)
(We still play NES as well, though. Nothing like a good 8-bit classic on authentic hardware
