Originally Posted by
anthonymoody
Well it could definitely be sub par image processing in the TV. Assuming the PS3 is feeding 1080p (which would not undergo processing in the TV) and the stb is sending 720p and/or 1080i, both of which have to be converted to 1080p, then the problem could definitely be with the set's processing.
Not saying there isn't a setting or combination of settings on the TV that couldn't be dialed in to have the image processing look good. But based on what is being described it seems to me that the processing is the likelier problem than the content itself.
Yep that's what I thought it's a bug in software ......that crops up on a FIOS signal ??
OR it's a faulty hardware issue
BUT really it will boils down to is it certain sets ?>? OR just sets on a FIOS signal path ??
as it seems to be isolated sets , unless it's just on a FIOS signal THEN i'd lean to software being a problem .
On a 844 in general, the problem is not a wide spread issue as there are Huge numbers of Happy Campers out there ,
I do recall that there are reports that some members had issues with the 632 80" that were on a FIOS signal also .....
