Originally Posted by
Raym1234
Suzook,
Thank you for your consistently helpful posts. A couple of weeks ago you received your 844U and your post at that time indicated some initial disappointment with the PQ. Have you had the chance to further calibrate the settings and, if so, are you more satisfied with the PQ?
well I am going to be honest, I am still struggling to get a consistent PQ across sources. I have found that this set handles 1080p and HDX streams quite well. Problem is that anything less is a mixed bag for me. While I tend to try and watch higher grade sources, that isnt always
possible and you are subject to varying feeds. I am a full 14 feet from this set and I have seen instances that the PQ is slightly substandard compared to my 80 632 that is allowing only 10 feet of distance.
Its a keeper for sure but I have to be 100% honest that if an 80 Elite or bigger comes knocking..............
I also might add that the 10 point and proper calibration may do away with much of my issues.
