Originally Posted by twarman17
My BD player is the Denon DBT-1713UD. By hitting "Display" on the 844 remote you can see what resolution is being shown. When I have the BD player set to 1080P/24 that is what is shown on the TV. No doubt the 844U is capable of 24fps. The problem is that the 24fps setting is causing audio sync issues with my BDs. This sync problem goes away when the BD player video resolution is set to just 1080P (which I assume is 60 fps). When I hit display on the 844U the resolution is shown as simply 1080P.
I have no idea why this sync problem exists on 24fps.
Well like I stated, it depends on what the material you are watching. I have these bluray nature videos that I bought when bluray first came out, and if I watch them with setting the player at 24fps, I get horrible stuttering and audio issues. If I set it to 1080p, it works fine. Does your AVR have the lipsync function to help compensate for audio delay? If you say that all works well using 1080p. I would just leave it there and enjoy your setup. I really can tell much difference between 1080p/60hz or 24fps. If your using the auto motion feature(120-480), it's kind of a moot point anyway
