Originally Posted by Shady195
I don't think there would be much problem with bowing as their are the 2 center vertical support boards though I am not sure, for what its worth, I was standing on it (Im 6'1 230lbs, i asked my wife if it looked like it was going to break, she said it did not move at all, dident bend in or anything). Realistically if you want a stand really that sturdy, you would really need something liek the post above. I know its pricey, but its somewhat of an investment. I Kind of wish I just spent the money on something like that now, but I could not find anything that woudl go with the rest of my stuff at the time for under 800, a lot of the ones ive seen were all red/natural/tan colored.
I will see if I can dig up the TV stand that coems with the TV and see if it will fit on it.
As far as the speakers go. They are HTD Level 2 bookshelf speakers, Yes I have them all around, though I will be upgrading the fronts to towers, the bookshelfs give plenty of sound, but it feels so empty with the skinny stands so I'm just going to get the full towers to put in their place.
I purchased this one. No particle board there. It's very sturdy-- I sit/lay on it all the time when I'm tweaking things. My TV is mounted on the wall above it. You get what you pay for! Furniture is definitely not cheap...
Just a suggestion for your speaker setup-- why not just add a quality subwoofer instead of replacing your fronts? You're going to crossover at 80hz anyway.... just saying
