AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp AQUOS LC-60LE847U & LC-70LE847U Owners Thread
Official Sharp AQUOS LC-60LE847U & LC-70LE847U Owners Thread - Page 3
post #61 of 2438
Originally Posted by ListedGuru View Post
So you can adjust the Sharp so it doesn't have the SOE (soap opera effect)? I'm coming from a plasma and I can't stand the SOE. If no SOE and motion blur or judder?
-Guru
Yes, I found 4 settings so far: 480 Aquamotion/240 Aquamotion/120hz low/120hz high/off. I like 240 Aq. Oh, and av set to standard.
post #62 of 2438
Hmm... The manual only lists AquoMotion480 for the LC-80LE844. I'm guessing you must have updated the firmware and a new feature was added?
Originally Posted by Talk2Me View Post
Yes, I found 4 setting 480 Aquamotion/240 Aquamotion/120hz low/120hz high/off. I like 240 Aq.
post #63 of 2438
An interesting idea for next weekend from the page 43 of the manual:
"It is recommended that you do view 3D images if you have been drinking alcohol."
Is 3D viewing really that dangerous? Sharp makes it sound like a chip will be drilled into your head or something... I counted 15 caution notes for crying out loud!
post #64 of 2438
Under Advanced Settings scroll all the way down til you get to Film Mode and turn it OFF. That removed the SOE effect for me.
post #65 of 2438
I can only speak for the LC-60C847OU. And they were there before the firmware update yesterday. If you really need to see them, I can take a picture and post it (for $5.00).
post #66 of 2438
How about some screen shots
S~
post #67 of 2438
We love Photos here !
put it on my Account if need be
I'd rather owe it to you than cheat you outta of $5
post #68 of 2438
Just an fyi, I have had the LC-60LE8470U from CostCo and have watched 2 movies via our PS3. One was a bluray and one was streaming via Amazon Prime. In both cases, for whatever reason, the TV detected a 3D signal and popped up all the warning messages and telling us to put on 3D glasses. It was a 2D movie in both instances.
It happend numerous times during the bluray movie and was very annoying.
Have other owners had this problem?
Any ideas?
post #69 of 2438
Any ideas?
Don't have the TV, but it appears to be an option you can disable for the time being. System Options > 3D
Setup > 3D Auto Change on the TV
post #70 of 2438
As much as I really like this Sharp 60", I just found out this afternoon, Runco surprised me, and is sending me a new processor ($10,000) under warranty (their customer service has shocked me on terms of excellence, they make Oppo appear like a Chevy dealership). So, goodbye to 3D and honestly, a great eye opening experience. Sharp has really surprised me with their quality. In fact I was just watching Rango on Sharp's Netflix app, and it had a 4 star goose bump factor.
Wow, that is awesome. Then again Runco is expensive........
post #71 of 2438
Attached are pics of my motion settings. The model on the side of mine is LC-60LE847U. I see that your's is LC-60LE847OU; I'm not sure what the O means, but I don't have Aquamotion480, but have 240Hz instead!?!
What AV Mode is the Sharp set to? Mine is set to "Standard." Maybe this is the issue? Are you also saying you have motion enhancement settings with 3D turned on?
I've only been using it for an hour, but on bluray I see no SOE with 240Hz selected. Picture is fantastic and the perfect size for a fire place; makes the 70" version not worth the additional $1000 (unless you have a theater room).
post #72 of 2438
This actually works! I'm controlling Google TV via the Sharp's IP Control connection. If anyone is interested, I added the free home automation software (called Premise) I use to my signature.
Since I use Premise to control the TV using Sharp's IP Control protocol, I can pause TV when my phone rings, interface all controls with a web browser etc... I'll post the module for the Sharp on http://cocoontech.com/forums/forum/5...-home-control/ when I finish it if anyone wants to use it.
This is beyond the scope of this forum, but my plan is to use an RF remote to control the Sharp and CEC devices connected to it. Signal path is like this:
1. Use presses pause on RF remote (customized Universal MX-900 remote)
2. RF signal is received by the MSC-400
3. MSC-400 sends a serial command to my Premise server
4. Premise interprets the command and sends the corresponding IP Command to the Sharp, but can also do other things at the same time like send lighting commands to increase brightness when I hit pause or stop.
Neat. I was browsing the Sharp 847 manual and found the attached commands. It seems that all remote keys are now implemented under IP control: how awesome!
This would appear to mean you can control whatever is connected to the Sharp via the Sharps network cable like this:
Sharp IP command remote key pause rcvd over network -> pause command sent using HDMI-CEC to selected source -> selected source responds if HDMI-CEC is implemented on source device.
I'm not sure if these commands will work on the 735 as I just returned it today... I know none of these were listed in the older LC-70LE735 manual. The 83x and 73x are so 2011 (or more like 2005) when it comes to IP Control apparently!
post #73 of 2438
What 3D Glasses did you guys get for this TV?
post #74 of 2438
Can some one please look to see if Sharp has reduced or eliminated the clouding issue on the 847U? I currently own the 835U and contacted Sharp about the problem. I submitted pictures and they agreed that my TV was bad. I inquired about upgrading to the 847U and they said it was possible to upgrade with a fee; or I could take a refurbished unit. I'm concerned that a refurbished unit will have the same problem. Why else would someone turn the TV in? The Sharp representative did say that it's normal to show some uniformity issues in the corners due to the edge lighting. However, clouding is not one of them. On my set it's extremely noticeable when viewing at night and on dark screens. Tron is not an enjoyable experience. The majority of my issues are located in the center of the screen which makes it worse.
So could some one please test this out and see if you notice this? I'm trying to decide if it is worth the cost to get the 847U. I have not seen it in a store yet. So I have not been able to watch one. It's extremely difficult to see the clouding on any TV in a show room, as the lights are nice and bright. Thanks for the info.
post #75 of 2438
Please post pics of your issue and I'll compare to mine. My 847u does have flash lighting along sides and in the middle... So far only seen when changing input.
post #76 of 2438
I have been looking hard for the right 60" set, I had convinced myself to wait on the 945, but it sounds like its going to be late summer, if at all? No one can confirm if it will be released so this model the 847 seems like the next logical purchase.
Can anyone that owns this post some pics? Impressions? it seems only a couple of guys have them and I didnt see any pics. I have a 5 yr old 52" sharp that will get moved to the bedroom when I finally decide on a purchase.
I'll try to hit up a B & M store soon to compare these models.
post #77 of 2438
[attach]Attachment 243112[/attach]
please post pics of your issue and i'll compare to mine. My 847u does have flash lighting along sides and in the middle... So far only seen when changing input.
How does this compare to the LC-60LE847U? Hopefully it is a lot better. Thanks.
post #78 of 2438
Yup That Sucks ! I'd replace that display as well .....
post #79 of 2438
etc6849, Could u either take some pics of your clouding issue at night ( when lights are turned off) and show us ,please?...Thank u.
post #80 of 2438
I can try sometime this week. It's hard to see and I doubt my cheap camera will capture it. I only see it on a blank signal too, not during dark scenes (yet). The TV also times out on a blank signal, making the picture even harder to take.
It's nearly invisible with a dim room (unlike my old TV), only visible with no light sources on.
The flashlight effect may actually be better than my older Samsung LCD fluorescent TV, and of course the picture is much better over all There's no blotchiness like the 735u I returned, so it really doesn't bother me and probably wouldn't bother most folks.
My biggest issue (and it's a small one) so far is convergence. I fixed it by just disabling "quad pixel plus 2," of course, I already had noise reduction disabled too. Please reply about convergence in this post:
http://www.avsforum.com/avs-vb/showthread.php?t=1404836
post #81 of 2438
Ditto. That does suck!
What is your back light setting on? I had mine on +10 and it wasn't as noticeable as yours. I'll try to take one picture at full backlight (+16) and one at +8. My room has lots of windows, so I'll have to take the picture at midnight probably
post #82 of 2438
Here you go...
I did these tests using the AVS HD free calibration disc. I used "Near Black" from ColorHCFR and navigated to 2/6 (1% near black level) with all advanced features turned off (quad pixel, motion, active contrast) and brightness set to 0.
I used my Nexus S 4G phone (running ice cream sandwich, finally).
As you can see, in a perfectly dark room with an 1% near black picture, you can see a lot of clouds depending on the back light setting (hover over images and read their title for back light setting)...
If you know of an LCD that doesn't do this please let me know as I'd like to buy one Also, please make suggestions as I'm within my 10 day return period. However, whatever I buy most be as good of deal as this TV was (~$830 below MSRP).
post #83 of 2438
Here you go...
Thanks a lot..., I think It's not that bad as the redstang1993's clouding-issue , at least It doesn't appear In the center of the screen . It's 90 % acceptable, have you tried setting the backlight in maximun ( + 16 ) and turning on the scanning backlight 200? , These settings belongs to the LE 835 but It could be ok or help the LE 847 in order to avoid clouding pay attention on the pic taken in a completely dark room (flatpaneldshd-sharp LE835 review, I'm a new member, so i cannot put the link ) . Sorry 'cause my awful English,please...: (
post #84 of 2438
Here you go...
The clouding on your display is very prominet. I like my tv to be bright as opposed to dark, I would be willing to sacrifice some of the backlight, but completly turning it off or way down to try and control a defect is unacceptable. I would replace with a new one. As these are very new is there more than 1 panal number out there? I have pretty much zeroed in on this one since the 945 seems to be a mystery.
post #85 of 2438
Does anyone else have any issues getting their WIFI connected? I can't seem to get mine to connect.
post #86 of 2438
I also have some of the clouding issue, but its really not a huge problem unless its a completely black shot. If your looking for a screen that doesn't have that issue, then I guess this is not the one. Blu rays on this thing do look outstanding. Just saw Planet Earth and the close ups of the flowers have great detail.
post #87 of 2438
could you post some screen shots? we want to see just how good it looks
post #88 of 2438
Do you think mine is defective, e.g. another 847u wouldn't have the same issue? There's really no way to see the clouding in the store or in any bright room so I'd have to exchange mine for another and bring it home to find out... That's a lot of hassle for something I may never see except during one or two movies.
I'm hoping some others will post pictures of their worst case back light bleeding.
post #89 of 2438
If the display would be "perfect" except for 1 or 2 movies and its not going to bother you, then I wouldnt mess with exchanging it. I have not yet had the chance to check these out at a store so I cannot comment on other 847's.
My current display is a 5 yr old sharp aquos that had the infamous "banding" I can see it on white screens and sometimes when the input changes but while watching TV it's not noticable at all, therefore I can live with it.
For the money we pay for these tv's we expect them to be perfect, but they are not and alot of times you can adjust most of the defects out and alot of times if you dont go "looking" for trouble you wont find it.
Congrats on your new 60" I hope to have one soon also. Post some pics of screen shots if you can I'm excited to see them.
post #90 of 2438
Ordered a 70le847 today. Hoping to have by the weekend. Like so many others here, I don't have a camera with low light chops, but I'll try to run it thru a basic calibration and get some pics.
