Originally Posted by
hornedbronco
Hey Sid, I tried playing a sbs 3d file from MacBook
connected to tv via hdmi and the 3d was unwatchable. The same file when played via USB was very clear and smooth.
webaccount
It's a wifi problem, try connect the TV directly (
wire) to your router.
webaccount
Dude, you're clueless, the files can be streamed from a PC using DLNA or Plex media server, when the TV does it over wifi (and it happens to be far from the router) it freezes so much making it unwatchable.
Sure.
If I connect my laptop to TV directly via HDMI why would I need a router? Please read the posts carefully 'n please loose the hate
sid369
hornedbronco@ thanks for being patient and helping me out man!!!
I tried plugging in a ethernet cable directly from my TV to the Verizon Fios router and still while playing the 1080p 3dSBS mkv file I saw that it was trying to load the file meaning the blue line on the bottom of the player was filling up but at a very slow pace. I paused the video and it started loading slowly. This is not the solution as then I would have to let the entire movies load before I could play it so that it smooth.
Also, is there a way to connect the iphone or ipad to the tv. I mean I saw something as wifi screen sharing, but how to enable this on the iphone or ipad?
I noticed that the best way to view large file movies is via the USB ports. It is very fast and has instantaneous loading ... no buffer issues.
I check my HDDs and I have one formatted as FAT32 (w/ 4GB file size limitation) and another as NTFS (I access it on Mac via NTFS-3G plugin and it has no 4GB limitation
). My 3rd HDD which is formatted as MAC OS Journaled is not recognized by the tv; and the bad part is that this HDD has the most data I need to be read ... I need to find extra space to dump these files and reformat the hdd. As you said this reformatting to NTFS needs to be done on a PC; I'm not sure if there is a app for mac which does that.
The wifi screen sharing can be done if your laptop has an intel i3 processor and up which support WiDi (Wireless Display tech). I dont remember reading about ipad/iphone screen sharing on LG tv's ... I'd guess you need AirPlay for that to work.
