Two bits of info:
Firmware from Amazon
We ordered our 55" from Amazon on 3 Jun. It was delivered later that week, and reports:
Model/Type: 55LM6700-UA
Software Version: 03.02.83
So you might get new firmware, you might get old. I live north of Denver, and suspect it depends on where Amazon actually ships from. Or it could just be the luck of the draw out of the warehouse.
Logitech Harmony Remotes
We use Harmony remotes, and have a 650 in the living room. To program them I use the Logitech Harmony Remote Software, v. 7.7.0. For grins I decided to try telling it my TV was a 55LM6700. That kind of worked, but not as well as possible:
- No HOME button
- No red and green buttons (not on the Magic Remote either)
- Has useless "Input AV2" and "Input Component2"
- "BACK" is labeled as "EXIT", works as expected
So then as recommended earlier in this thread, I deleted that device and tried the TV as a 47LM860v. That worked much better. It still gave some buttons that are not useful (e.g. Input Av2), but covered all the buttons on the Magic Remote and more (no Magic or scroll wheel). The color buttons work, HOME works, and there are even some useful things not on the Magic Remote. I deleted the ones out of the configuration that I didn't see ever could be used, but for now left in things like the DVR buttons in case we figure out how to enable that functionality.
Edited by foomench - 6/11/12 at 11:19pm
