I hope that someone here can help me with Reclock in combination withTMT5
At first: I assume that Reclock should also work when I play Blu-Rays, from folders, with HD sound, e.g. DTS-MA. If that is so, I wonder what I am doing wrong, because I don't get sound that way.
I have a Xonar HDAV 1.3 Slim soundcard, connected with my A/V receiver via HDMI. In TMT5, AV Center, I set Output to HDMI and Mixing Mode to PCM Uncompressed Audio.
When I start a Blu-Ray, I see PCM and 6 channels on the receiver's display but no sound is heard. When I click on the Reclock icon in the system tray it says however "Audio 48000Hz, 2 channels, 16bits PCM. So Reclock reports 2 channels instead of 6.
Btw, when I don't use Reclock I do get sound with the same settings in TMT, with 6 channels of PCM. And dvd's and videos (e.g. mkv's with flac, dts and ac3) play fine in TMT5 (and MPC-HC) and Reclock. The only problem I have is with Blu-Ray's.
And another question: My TV supports 23 and 24 Hz. What should I choose for Reclock ?
Thanks in advance for any help.
