AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic ST50 Series Discussion Thread [No Street Price Talk]
Official Panasonic ST50 Series Discussion Thread [No Street Price Talk] - Page 63
post #1861 of 9472
Originally Posted by nitz369 View Post
Okay I am stuck on what to do. I love this tv except I haven't played with an LED in my house. I don't want to exchange through amazon because its a lot of work when I am not positive. Just want someones opinions. My issue with this tv is on my streaming MKV on the ps3 seem to have issues with dark items. Not scenes. So let's say a guy is wearing dark jeans black coat and blue shirt. The whole body looks black with no definition between items. This is true with all dark items. I have played with settings and can't get it to look right. When I watch tv its not like that but tv episodes usually are brighter. And I know MKV is not original bluray quality but they didn't look like this on my DLP.
Should I be happier with LED? Is this something I need to get used to? Is there settings that are wrong? Someone help me make this decision.
Well first of all, are you watching in a very bright room? Black on a plasma can only get as low as the color of the actual screen in a bright room.
If not, sounds like a settings problem in the ps3 or tv. Have you made any changes to settings in either? Raising brightness should fix the issue, if not than what the tv or ps3 considers the blackest black is wrong. Is the "black level" setting in advanced picture submenu set to light? If its set to dark that would be the problem. Not sure what similar settings in ps3 are.
post #1862 of 9472
That review is one of the most idiotic reviews I've ever seen. ST50 isn't even being measured in half the measurements. I wouldn't trust the guy with my meal order, nevermind handling calibration equipment.
post #1863 of 9472
Could you post what your connections and settings are and maybe someone can really help you.
post #1864 of 9472
Well after returning my st30 due to some green pixelation, I bought a 55st50. I just set it up and started running the prep slides. No green or pink blobs.
I did notice the buzzing on it, especially when going through the brighter slides. It seems to quiet down with the darker ones though. It is louder than the st30, and I could notice it right away.
I realize that there is no perfect tv and every set might have its little quirks. Sometimes I wish I didn't discover this site so that I wouldn't be so picky when it comes to a set lol.
post #1865 of 9472
Started with d-nice custom settings and moved slightly from there. I found raising brightness and lowring gamma to 2.0 help but then blacks start looking grey. When o am watching it is in dark room. Ps3 is hooked via HDMI.
post #1866 of 9472
yep, i'm pretty sure you need to hunt for how to change the black level in the ps3 options. it will make a huge difference.
post #1867 of 9472
Did some searching on my ps3, looks like the setting under display setting called "rgb full range" could clip blacks if set incorrectly, does changing that setting fix the problem?
Also just to make sure, double check the setting on the Panasonic called "black level".
post #1868 of 9472
Black level on TV is set to light.
Changed RGB to Limited, didn't really notice any difference. I will continue to do some troubleshooting. I started by moving the WD Live to the panasonic and working with the same file. It seems to be slightly better on the one movie I have been working with lately. I am going to grab the bluray of this movie tomorrow and see how to true bluray looks on this TV as well as a smaller LCD and DLP.
Now one question that might eliminate a "middle man" how can I play MKV directly from the Panasonic? I have done a couple searches not pulling up much, but currently using PS3 Media Server as DLNA and none of the MKVs will play from the TV directly.
post #1869 of 9472
It sounds like a colorspace(RGB) issue. You may try setting the PS3 to a limited/expanded colorspace and matching the setting on the tv.
On the MKV thing, The tv won't do DTS and someone else had a suggestion of using "popcorn mkv" to convert to ac3 audio. I haven't tried it because Mezzmo is working fine through DLNA over the wireless.
post #1870 of 9472
Originally Posted by Mr2Spyder View Post
Interesting review..
http://www.televisioninfo.com/conten...TC-P50ST30.htm
I'm surprised they concluded it is really not much of an improvement over the st30 especially after all of the other stellar reviews...
Television Info dot com is known for having inaccurate information and inaccurate reviews over the years so take anything they say about TVs with a grain of salt. Not sure who they are or what their agendas are, other than having lots of advertising.
Stick with known reviewers and calibrators for the real info.
post #1871 of 9472
My favorite line from this review
"For commercial breaks, credit sequences, and really dark scenes in movies, there's nothing like a plasma screen."
If that's what he really thinks that great black levels are for then he has no business reviewing televisions. I think he is nothing more than an LCD shill.
post #1872 of 9472
Originally Posted by eagle_2 View Post
"Last year, the contrast ratio was greater, the color accuracy more accurate, there have been no new ports added, nor has the online interface been updated at all. The biggest advancement we noticed was the 2500FFD function, which seems to have improved the motion processing, but this is not enough to constitute a whole new line of more expensive televisions in our regard. Look to get last year's model if you are considering this TV at all."
"Blacks & Whites
The ST30 has the advantage here with the same black level, and a much better peak brightness."
"The superb black level on this Panasonic yields a strong contrast ratio, despite the oppressively low peak brightness. It has been a while since we saw a television show images this dimly"
"Color Accuracy
Both the color temperature and the color detail proved to be better on the ST30 from last year."
Yet then they say later:
"The color gamut proved to be fantastically accurate, but the detail throughout the brightness spectrum in both the primary colors and the grayscale tested sub par. It's a good panel, with some improvements on last years ST30 model (as well as some regressions), but not the best we have seen, even this year."
"Panasonic got it almost exactly right with the cinema mode on the Panasonic TC-P55ST50."
Are they contradicting themselves? They don't sound very enthusiastic, and it seems quite different from what other reviewers are saying. I definitely don't like how they say last year's had more accurate color and much better peak brightness. Is this true or do they not know what they are talking about? It shouldn't be too hard to measure color accuracy - either this set is better than the ST30 or not. Now I'm already starting to wonder if I made the right choice with the ST50.
According to that review, the whites aren't nearly as bright this year, which seems to go against everything I've heard others, including Panasonic, say. They repeatedly talk about how dim the set is. And they completely trash the 3D capabilities, calling it shoddy and an afterthought. This is a very troubling review if this is correct. My set is being delivered tomorrow and I'm already concerned now.
I do find it hard to believe that this review is accurate. Everything they say goes against the other reviews I've read so far.
I'm starting to get doubts as well after reading this review. Everybody else is saying this is an improvement over the 30. But after reading this, should I spend less for the 30? I'm confused as well. Help folks.
post #1873 of 9472
Surely you're not giving any validity to that review. It's trash
post #1874 of 9472
It did get a 10.2 out of 10 for performance!
post #1875 of 9472
Originally Posted by randywalters View Post
television info dot com is known for having inaccurate information and inaccurate reviews over the years so take anything they say about tvs with a grain of salt. Not sure who they are or what their agendas are, other than having lots of advertising.
+1
post #1876 of 9472
Ok worries subsided. Trash review.
post #1877 of 9472
PS3 set color space to limited, Super White "on".
post #1878 of 9472
Read Chad's review he knows his stuff.
post #1879 of 9472
While this review is of dubious quality to say the least, I don't think he meant that exactly as you think. Of course black levels are for much more than he mentioned but in terms of commercial breaks, credit sequences and dark scenes as he mentioned he was spot on, a plasma TV rocks and nothing beats it in terms of overall black levels, not even the Elite as it starts to lose a small bit of black level when you view off axis.
post #1880 of 9472
Originally Posted by etc6849 View Post
Setting "Motion Smoother" to medium seems to fix the stuttering on panning scenes (I had it set to off). However, setting 24p Direct in to 48Hz still causes flickering?!?
I cannot find this option. Can you tell me where to find this?
post #1881 of 9472
Where do I find Chad's review? Thanks.
post #1882 of 9472
Clevelandplasma.com under 2012 Television Reviews.
post #1883 of 9472
I second that
post #1884 of 9472
Anyone having issues with the built-in Netflix playback? Whenever I watch Netflix, every 5-30 seconds (greatly varies) there seems to be a black flash on the entire screen for maybe 1 or 2 frames. I've tried different content (HD movie, a cartoon, and a documentary) and it happens with all of them.
It does not happen with my HTPC, Bluray, or other through the Panasonic YouTube player.
What's up with that? Known bug or weird isolated issue? Should I exchange it for a new TV?
post #1885 of 9472
Just use blue ray player to play Netflix. I have Netflix access on my tv, Xbox and blue ray. I found that Pannasonic 220 has the best out of the three for streaming quality, although the interface menu is slow. Xbox has the best Netflix interface but streaming is not as good as blue ray player. I wouldn't exchange the tv. Are you wireless or connected through Ethernet cable?
post #1886 of 9472
This is being caused by the resolution of the Netflix video stream automatically adjusting to bandwidth/network/server load changes. If you press the "Info" button on the TV remote the app will display the current res of the stream, and you can watch the changes coincide with the frame drops you're seeing.
post #1887 of 9472
that is dissapointing. i'm going to be depending on the netflix app built into the TV.
post #1888 of 9472
Well my 55" ST50 arrived today in perfect condition, and the guys set it up on the stand for me. I'm currently running D-Nice's slides according to his recommendations, making sure to follow all instructions for photo settings.
A couple quick thoughts so far (keeping in mind I just traded in my Samsung D7000 for this):
- The printed manual is a joke. It only covers the most basic of settings and setup. Instead of printing the manual in 3 different languages, but omitting almost everything, how about printing up a thorough manual in, you know, English, since I bought this set in North America. Yeah, I know it has a built-in manual, but that's besides the point. The printed manual could be way, way better.
- The frame and stand are nice, though of course more plastic than the D7000 had. Still a very nice looking frame.
- I'm very disappointed to discover that the stand does not swivel! Are you kidding me, Panasonic? The 50" model does but the 55" doesn't! Unbelievable. That's a major disappointment for me because it is quite difficult for me to get behind the set, which I do somewhat regularly, since all my pc, receiver and other cables are all behind the stand and sometimes I need access to those, as well as getting to the surge protector strip. How much would it have cost them to include a swivel stand - $2? Please, charge me $10 more for the set, I don't care, but give us the swivel stand!! Now I need to keep my eye on a swivel stand, which means money.
- Also very disappointed to learn here that the built-in media player does not handle DTS with mkv files! WOW! The D7000 did. Another huge disappointment that means I immediately need to purchase a media player now, or at least a new blu-ray player that supports mkv/DTS support. Why support mkv playback if DTS isn't supported? Huge disappointment because we really don't have any additional money for a media player right now - I knew this tv supported mkv so I figured it would get me by until the day I can afford a decent media player. More money.
- I am noticing some very slight pink discoloration around the bottom of the screen during the slides, noticeable when the grey slides are being displayed. I am hoping it will disappear during the initial break-in slides, but I don't know if it will or not. It's very minor and as of right now the set has only been on for about half an hour. I'll report back on this after my break-in is finished. I'm hoping by the time the slides are done, and I use D-Nice's settings, hopefully that will be gone.
- Buzzing. Very disappointed right away with the buzzing. I can tell you that I owned the D7000 for almost a year, and I sat right next to it when I used my pc, since it is very close to the tv stand, and I never - never - heard any buzzing. I had to literally put my ear to the D7000 to hear the very slight buzz coming from that set. Right now, I can easily hear the buzzing from about 3 feet away. I don't know if people here would consider it abnormally loud since everyone has a different threshold for what they consider loud, but compared to my D7000, it is loud. Right now my pc is on too and the fans are quite loud in my pc, and I can hear the buzz over the pc fans. When I get right over the tv I can really hear the buzz.
So far, since I have no experience with the picture quality since I'm running the slides, I can only comment on my initial impressions. And so far, it's a mixed bag. No swivel stand, no DTS support, noticeably loud buzzing, and a slight pink tint near the bottom - all make me a bit nervous. I'll certainly give it a chance, and hopefully the image will be so good that I can overlook some shortcomings. I hate the thought of returning back to Samsung. Cautiously optimistic.
post #1889 of 9472
Since I'm running break-in slides I cannot check that, but this weekend hopefully I'll give Netflix a try and see what happens. I'll report back on this after I try it.
post #1890 of 9472
Check this out for swiveling. http://www.magicsliders.com/
If you place the sliders in each corner, I doubt you'll lose any stability and you'll have no trouble swiveling. You could also place 4 in the corners and one each in the front and rear center if you really want to distribute the weight.
I'd go for the thinners, smallest of the sliders. If those make you uncomfortable, any Home Depot or Lowe's will also have the felt stickies you can put on furniture feet. They are even thinner and should give you a nice, invisible "swivel" effect.
