Originally Posted by whipit
If you have the eco setting enabled the tv will shut off if you don't touch a button on the remote or side panel, it's in the manual.
"No activity for 3
hours
(Stay on/ Power
TV off)
To conserve energy, the TV automatically turns off when no operation of remote and
side panel key continues for more than 3 hours.
Not in use when Auto power on is set to Yes, or On/Off Timer is set.
No activity for 3 hours was activated will be displayed for about 10 seconds when
the TV is turned on for the first time after the power was turned off by No activity
for 3 hours.
The on-screen display will flash 3, 2 and 1 to indicate the last three (3) remaining
minutes prior to the shut-off."
"No activity for 3
hours
(Stay on/ Power
TV off)
for 3 hours.
3 hours ? hehe, but what if you are watching Lord of the Rings (extended)
. But to be honest, you paid for a set that advertises a feature and regardless whether or not you couldn't care less if it works or not you're entitled to have a TV that works. It's up to you but I would at least go to a nearby electronics store that carry's the ST50 and try your SD card in one of the demos just to be sure your TV isn't defective. No need to give Panasonic good money and settle for a set with an obvious defect. If your card doesn't work in the store demo then it could be just that particular card that the ST50 isn't compatible with. It's best to know.
