Originally Posted by brianshaun85
I'd like to know if they work with the tv too.. They are much cheaper then Panasonic 3d glasses.. I would get them as extras if they do work. Panasonic should lower the price of it's 3d glasses so people can get more and be able to afford glasses for the whole family. If Samsung is able to sell it's 3d glasses at such a price then Panasonic should be able to do so.
While I do agree with you that the price of 3G glasses is insane to say the least there is a major difference between the active shutter Samsung's and the Panasonic's. The Samsung's are cheaper because they are battery operated and Panasonic only sells rechargeable glasses which is why they are much more expensive. Personally I would prefer to have battery operated glasses so I never have to worry about the glasses becoming useless once the charging cells begin to have a shortened life.
One other thing to note, the new Panasonic glasses (which only work with the 2012 Panasonic TV's) have a quick charge feature that can charge up to 80% in about 30 minutes. Other rechargeable glasses take several hours. I bought mine on Amazon for a good deal. Not sure if the Sammy's work on the Panny TV's but I would recommend just buying the Panny's for best results in regards to syncing to reduce any chances of crosstalk.
. But to be honest, you paid for a set that advertises a feature and regardless whether or not you couldn't care less if it works or not you're entitled to have a TV that works. It's up to you but I would at least go to a nearby electronics store that carry's the ST50 and try your SD card in one of the demos just to be sure your TV isn't defective. No need to give Panasonic good money and settle for a set with an obvious defect. If your card doesn't work in the store demo then it could be just that particular card that the ST50 isn't compatible with. It's best to know.
I guess I might just have to buy some n see
