AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic ST50 Series Discussion Thread [No Street Price Talk]
Official Panasonic ST50 Series Discussion Thread [No Street Price Talk] - Page 106
post #3151 of 9509
I went to my local Paul's Tv to check out an St50. I don't know if it's the set up that they have but the set did have some sort of static. They were showing an animated movie, but I could see static or small color dots lighting up the entire screen. You could really tell in the widescreen black bars. Is this normal for a plasma or just bad static set up on their part .
post #3152 of 9509
Originally Posted by rjm-1 View Post
Oh Oh! Thanks Randy. I'm new to this forum and really don't know too much about this stuff. But I recognize your name as one of the more knowledgeable on this forum. I thought the same thing as far as being defective but after the Panasonic rep said it was the way I had it connected, well I figured I'd ask the forum members for input. I purchased it at Best Buy with a 4 yr extended warranty. Should I call them to replace?
I purchased the TV on April 30. So I'm within my 30 days. Off to Best Buy this morning to ask for an exchange (bringing copies of the picture I posted). Thanks for the help and all the advice on connection sequences. Not looking forward to the 100 hr aging, but it seemed to produce a great picture. Thanks, Rich
post #3153 of 9509
If there were any issue with the connections or an HDMI handshake issue it would affect the whole screen evenly, not just the lower half. And that scrambled colored interference pattern on the lower half looks like a board failure - it doesn't look like a handshake problem. I'm 99% positive that the board that drives the lower half of the screen is either failing or maybe the ribbon cable is just loose.
This could get tricky. I presume you're within the 30 day BB return window for the TV and also for the 4-yr EW so i'd return the defective TV for exchange (which should be no problem) but if you get a replacement TV make sure that EW that you bought gets applied to the replacement TV, and get it in writing. The fine print in the BB warranty states that if they have to replace the TV under the EW, the EW is considered "fulfilled" and is cancelled, screwing you out of the remaining years that you would have been covered for and you then have to buy another EW for the replacment TV.
So be sure that the STORE is replacing the TV, not their Extended Warranty department. If there's any ambiguity, return the EW for a full refund then buy a new EW for the replacement TV (and i'd consider getting a Mack EW instead of the BB EW).
With any warranty repair, you never ever want to utilize the EW while the TV is still under the one year factory warranty because if the cost to repair is too high, you use it all up too early and then it gets cancelled. Let the manufacturer handle all the repairs for the first year and leave the EW completely out of it until that factory warranty expires. And if you suffer a failure a few months after the factory warranty expires, Panasonic has been very good about covering the repairs when asked (many people here got free repairs even 3 months after the warranty expired).
If you don't want to deal with exchanging the TV, or if you're beyond the 30 day return policy window, then contact Panasonic and email them that picture and get a repair visit scheduled.
Edit - oops, i see you posted that you're returning the TV while i had my reply window open for a half hour. Just be mindful of the EW issue for the new TV.
post #3154 of 9509
Originally Posted by jonnythan View Post
Same thing at my Best Buy. The 55ST50 was in a 3D display and mounted right next to an eye-searingly bright LED but with good lighting. The 60UT50 was high near the ceiling and washed out by the bright pendant lights.
It prolly wasn't the lighting either,I went into 2 different best buys and both had the UT50 set for home use on standard mode for some reason,they were so dim I had to change them. Not having the filter does make them look dim but it doesn't make them look that bad.
post #3155 of 9509
Sounds like bad setup to me. They're probably using some sort of lousy component or even s-video distribution system.
post #3156 of 9509
Yeah the screen looked terrible. I wonder why these retailers think they can sell tvs and display them so badly.
post #3157 of 9509
So I finally got my 55 ST50 set up last night. Tried a mix of Netflix (via PS3) and FIOS. I'm sure it's covered somewhere in this thread but does anyone know why :
(1) standard mode looks like utter garbage
(2) even in cinema mode the picture seems soft or just off in some way I can't quite describe, especially with FIOS content.
Contrast and black levels are amazing though. Kicks my 5 year old Samsung plasma in the teeth.
post #3158 of 9509
Surprising that the picture would look soft even with the FiOS content. Have you had a chance to check out any Bluray material yet?
post #3159 of 9509
They are using that kind of distribution system...but unless a particular cable was bad that wouldn't explain why the UT panel I saw looked so much worse than every set within 20 feet of it. The picture was dark gray. Regardless of how poor the quality of the source is, all the displays are getting the same feed. That said, it's also possible that someone messed around with the settings and turned it to crap. lol
post #3160 of 9509
Standard mode is garbage. Cinema has bad gamma which will produce a washed out look. Try Custom and adjust the settings a bit - turn off all processing, lower Contrast to somewhere between 80 & 90, Brightness to 53-55, Color Temp to Warm 1 or 2.... These are just general suggestions, try adjusting them one tick at a time until you get an image you like. Also, you may want to adjust Color up or down too.
post #3161 of 9509
Thanks Randy. Can you suggest a good connection sequence and type of cables to help reduce HDMI handshake? Handshake has been a problem with my set-up on my last Smasung LCD also. I have a Scientific Atlanta cable box, a Denon AVR-1611 receiver, and a Sony Playstation 3 for playing DVDs (not into video games).
post #3162 of 9509
"and i'd consider getting a Mack EW instead of the BB EW"
do you have any comment about Mack EW compared to SquareTrade?
post #3163 of 9509
How about DTV Express Warranty?
post #3164 of 9509
Hi Chas, I don't know a lot about Mack but I do know that SquareTrade is highly rated and very high on customer satisfaction. One thing to know (which I recently found out) that ST gives you a spending limit. For example if your TV costs $1500 then that's your spending limit. If you need service and contact ST and they perform a service that cost them $500 worth of parts and labor they will deduct that from your $1500 spending limit leaving an amount of $1000.
Say after that $1000 remaining balance you have more problems down the line and ST realizes they cannot repair it and you need a replacement TV, they will send you a check of the remaining spending limit of $1000. From then you'd use that amount towards a new TV if you so choose.
post #3165 of 9509
65ST50 will be delivered tomorrow between 11 and 1. No questions, just wanted to share the joy
post #3166 of 9509
yeah what you just explained about Squaretrade is the reason I'm considering buying an extended warranty direct from Panansonic, even though its double the Squaretrade warranty price. (I think they issue it through Servicenet, same as Sony)
post #3167 of 9509
No.
It could be a lot of things other than the display. Two possibilities would be a bad source and bad HDMI or other cables.
post #3168 of 9509
It's sad and frustrating every time I go into my local best buy (which is often) to see they always have their ST50 prominently displayed, but set on "Standard". The look is washed out grayish and dim.
They'd sell so many more if they're just put it on "Cinema". I'm sure many people dismiss arguably the best set on their floor just because of how it's setup in the store.
post #3169 of 9509
you rock HLdan. thank you for the excellent reply. that sounds like ok terms.
will probably go with ST.
post #3170 of 9509
60ST50 is coming tomorrow also. Hoping for a good set.
post #3171 of 9509
Same here! Between 8 and 12.
post #3172 of 9509
3-7 for me. Coming from a 50". This could be epic.
post #3173 of 9509
Hah, me too. 2006-era 50" Maxent plasma.
post #3174 of 9509
Adjusted Custom is better, at least so if you believe Chad B's review, since Cinema has bad gamma which results in a washed-out look.
post #3175 of 9509
Are your hdmi cables high speed 1.4?
post #3176 of 9509
Congrats! I'll be ordering the 50 ST50 later this summer.
post #3177 of 9509
Is it possible to turn off the viera sign when you first turn on the tv?
post #3178 of 9509
If looking at SquareTrade, check the pricing at CostCo.
You can purchase a ST warranty from CostCo even if you bought the TV elsewhere - but you must do so within 60 days of your purchase.
Also check out this article from Plasma TV Buying Guide for some great Consumer Information about after-market warranties:
Common exclusions from coverage among all of the TV warranty service contract providers are:
Extended Warranty Starts from date of purchase of the TV and run concurrent with the manufacturer's warranty. The manufacturer's warranty supersedes the extended warranty during the first year.
TV screen burn in not covered.
Cosmetic damage or physical abuse
Pixel defect policy same as manufacturers policy
Pre-existing conditions that occur prior to effective date of contract
Manufacturer's defects occuring during the manufacturer's warranty period
TV must have valid manufacturer's warranty for at least 90 days
TV with removed or altered serial numbers
Cancellable within 30 days for full refund
Almost all cover damage caused by power surge or lightning
Any and all consequential damages
Following are the categories we felt were most noteworthy and important to the end user. We've come up with the following names to describe the most damaging clauses as "the buyout clause", "the dump clause", and "the strict limitation clause". A description of these clauses follows and explains why they are dangerous....
(See the article for more details & a nice Comparison Chart!)
post #3179 of 9509
We're using Cinema on our 60" ST50 - with Slight Adjustments as suggested by running the AVS HD 709 test disk - and are Very Happy with the results. Certainly do not see any indication of a "washed-out look."
Will give a run using Custom - probably within a few weeks - but on the ST30 we could not obtain as nice of a picture with Custom as we achieved under Cinema, and a VERY Superficial initial comparison suggested that that was also true on the ST50.
OTOH, there are a LOT more adjustments that can be made using Custom, so perhaps that mode will prove more advantageous than it did on the 30....
post #3180 of 9509
Newb question here. My set is scheduled to be delivered tomorrow. I am planning on running the prep slides, but I am going out of town this weekend. My question is... can I start the prep and then leave the tv off for a couple of days and then resume when I return? Also, is there a big difference between the prep settings and the out of the box settings that are posted?
